Ya, hast du das einverstanden Eldo?
Edit:
Poor memory, should be more like
verstehen sie Eldo?
Looks like "Sleeping With The Enemy". LOLThe tracking information says Fed Ex destroyed my package.![]()
So now I have to wait an extra long time to get my Kwazar sprayer. This sucks.![]()
I was referring g to your "tidy" shelf arrangement, Eldo.
Sent from my SM-G955U using Autogeekonline mobile app
@Crovello. Griots Garage just released their own version of pump sprayers. You might want to look at them and see if there’s a warranty on them. If there is you can rest assured because at least you know you can count on Griots to stand behind their product.
I’ve had the red 1 for almost 2 months and it’s still working fine. I only use it for Wolfgang Uber & Megs D114.
If you’re looking to use it for Wheel Brightener you’d want the Black 1. Good luck, Wheel Brightener’s been known to eventually destroy sprayers and I’d be curious to see how long it holds up.
Whatever you do don’t weaken the dilution to anything below 4:1 just to try and preserve the Kwasar, that wouldn’t be worth your trouble. 4:1 and it better hold up it’s end of the bargain.
Make sure to update us if you decide to buy it.
If you're recommending the black one because of the metal tip you don't want to do it. I've tried wheel cleaner and Iron remover in these and it didn't work out. It may have been the because the liquids were thicker, but after trying the sprayers wouldn't work at all. The importer of these bottles sent me some plastic tips to replace the metal ones and they work again.
Which wheel cleaner was it?
From the Griots product description, looks like it does not like solvent based cleaners.
"Note: Sprayer is not intended for use with Black Shine High Gloss Tire Spray, Chrome Wheel Cleaner, Undercarriage Spray, or liquids that contain acids or solvents."
I used the Kwazar Mercury spray bottle with some Wolfgang wheel cleaner, sprayer was destroyed in no time.
