kjn
- Oct 18, 2013
- 121
After compounding and polishing I don't usually bother with an IPA for a wax or sealant application.
Does fg400 or 2500 contain any fillers or oils? I have both but haven't used them yet. Thanks
Yes for oils - no for fillers.Does fg400 or 2500 contain any fillers or oils? I have both but haven't used them yet. Thanks
Some of these alleged filling issues are caused by inadequate work times. With these diminishing products, this can sometimes take a few minutes. Colder weather, softer pads and lower powered machines are all contributing factors. You really need to work the polish until its clear. I've found the best method is to move at a very, very slow arm speed at a high speed for 1-2 passes to get the most cut and best finish.
I might have to add that to my never stopping growing arsenal. Great review.
Probably too much product. How much are you using?
As far as difficult wipe on, it can sometimes be more difficult due to the oily composition. However, if you do not work the product long enough for full breakdown, this will be an issue.
I'll try tangerine hydro tech pads tonight and see. Or should I try rupes white pad?
Sent from my LG-E970 using Tapatalk 2
I was using between 4-5 on both machines. I think cyan is going to be too much cut for me. I was using white ccs polishing pads. The truck is a 2013 and has been very well cared for by me so I am just finishing it before sealing. Maybe I should drop down to the 4000 on a white rupes or tangerine pad. Or use Rupes Ultrafine on a white rupes pad.
