Review of Griot's Garage Liquid Gloss Poly Wax
osiapstndp
Hello everyone,
Today I want to share my recent experience with Griot's Garage Liquid Gloss Poly Wax. I first saw the product on Auto Geek, but initially thought it was not worthwhile - it's just another sealant. After hearing positive buzz about the product on the Auto Geek forum I decided to try it out.
My black Challenger was the first subject on which I tested. The Poly Wax applied smoothly with my Flex 3401 and it removed off of each surface with minor effort. As a bonus, the sealant smells like Christmas! That may be an odd simile, but it sticks.
The result of the first application was good, by which I mean similar to other top-tier sealants (in my book) such as Wolfgang Deep Gloss 3.0 and Jescar PowerLock.
Fast toward a bit and I ended up using Poly Wax on a few customers' vehicles with no complaints or issues. Great!
My wife has a 2006 Ford Taurus with paintwork that shows signs of its end of life, such as haziness, cracking, brittleness, and whatever else one may think of. In addition, the car is the victim of multiple hail storms and it only gets washed and "detailed" very infrequently. The car sits outside 24/7 and contends with a neighborhood of stubborn trees that like to have their way (that means a filthy vehicle).
Approximately five months ago, with almost no daylight to spare, I hurriedly performed a waterless wash on all of the exterior surfaces of the Taurus with D114. Afterward I decided to apply Poly Wax to the paintwork with what I had on hand - a microfiber applicator. The sealant didn't perform miracles, such as replacing haziness with clarity, but that is not expected with a product whose purpose is to protect the paint's finish.
Now, here comes the fun part! After all this time my wife's Taurus has not been washed, clayed, re-sealed, or otherwise cleaned since I last touched it many months ago. Below is a testimonial to the endurance of Griot's Garage Liquid Gloss Poly Wax, even on a car that suffers so much neglect.
The Roof
The Hood
The Deck Lid and Spoiler
The Roof
I will summarize my experience with a single interjection. Wow!
This product earns a 5/5 from me in the categories of ease of application, removal, overall look and feel, and especially durability. I normally don't care about water beading, but it was mighty cool to see such a characteristic of five-month-old sealant.
Thanks for sharing that....this is on my 'should try' list.....maybe it needs to move up
I like it so much that it is now my go to sealant. I have used many sealants and this is my all time favorite.
it seems that GG went back to the drawing board (maybe/maybe not necessarily this product but just in general) and made some existing products even better and i'm sure they will continue to keep doing so wherever they feel necessary to improve upon. nice review, thanks for sharing!
I'm a huge fan of 4*UPP, but you gents have convinced me to give this one a try.
It ranks up there at the top of my sealant list (along with their BOSS sealant). The BOSS sealant has some correcting ability (more like an AIO) whereas PolyWax is pure protection with no correction. It IS durable as h*ll!!!
ScottH
Awesome feedback! Thanks so much! Poly Wax available in gallons if anyone is using it professionally. More to come guys!
Jeff
What is the cure time you use before buffing off this sealant? Are you spreading this very thin with a machine?
Does the Liquid Gloss Poly Wax stain trim?
Finished with some Poly Wax this weekend after a light polish:
I've only had a chance to do a little bit of testing on a spare Audi grill I had laying around, and found it gave the plastic a nice even sheen.
I actually treated several of the slats with Wolfgang Exterior Trim Sealant, and several with Liquid Gloss Poly Wax. Trouble is, I forgot to mark them, but after sitting for a few weeks, I can't tell a difference between them. It hasn't been out in the sun at all, not sure if that would cause any negative effects to be more obvious. Haven't played with getting it on rubber trim/weather stripping to see if that stains.
Heisenberg: The Nissan looks awesome!!
I allow for an hour of cure time on the low end, and 4 on the high end. I am sure more time wouldn't hurt, but schedule usually doesn't allow for more. One awesome product!
ScottH
I'll check the Bottle for it's recommendation for when to buff off after applying, but Jeff Brown had recommended 24 hours to cure (crosslink) after applying before exposure to moisture or applying a second coat. He did say 2 thin layers would deliver even better durability.
When I've used it, I've just applied a thin layer with a red foam pad. Buffs off extremely easily!
Checked the bottle:
1: Apply a thin, even coat to paint surface by hand or obital.
2: Allow to cure for 10-30 minutes depending on temperature.
3: Wipe initial residue with a clean microfiber towel, then turn cloth over and lightly buff to high luster.
Hello,
Two weeks ago I applied the sealant when it was 65 degrees. I thought it was going to rain so I was only able to leave it on for 15 minutes. We had a rain storm during the night so I applied another thin layer when it was around 53 degrees, 24 hours after the first coat. I was only able to leave that on for 15 minutes. Was this enough time for the sealant to cure on the paint? It's 65 and I'm wondering if I should put another coat on and let it set for 30-45 minutes.
Thanks
I can only spectulate, and hope an expert will chime in, but I would think you're probably ok? Just curious, Did you wash the car prior to applying the second coat?
If in doubt and you're shooting for best results, I'd clean the car and apply one last thin coat and let that have some cure time (both before wipe-off and exposure to water if possible).
You could always try calling Griot's customer service line, I've always had good luck when I've talked to them. Let us know what you end up doing!
Thank you for responding. Yes I did wash the car and sent a email to griots. There answer was that is was enough time the for the sealant to cure. I wanted to know other opinions. I want to make sure I'm not counter productive outing on another light coat.
I don't think it'd be counter productive; but if they thought it had enough time to cure it sounds like it would be strictly extra credit for added longevity and maybe some extra shine? Since it's strictly a sealant and doesn't have any abrasives I don't think there'd be anything counter productive with applying another thin coat.
Thanks for sharing!
That Nissan blue is one of the nicest colors on the road! I would buy the vehicle just for the color alone!!!!
ScottH
