I'm not sure why you continue to post this misinformation unless you have a hidden agenda.
That is a ridiculous statement. Why on earth would I have a hidden agenda? Could you please refrain from using such antagonistic language in your responses to me on this forum.
don't waste time testing the limitations
That may well be your attitude towards product testing, but it is not mine. How else would one know of the limitations of a product without “pushing” the product? Perhaps if you took a similar approach to my own in your testing, you would be more qualified to answer questions and supply the correct advice about the products you represent.
After contacting me and Dr. G and getting the same answer
Dr. G in his reply to me made no comment re the 60 day cure time test I’ve just referred to above. A no comment could hardly be described a user error.
not in a cleaning fashion, but made multiple passes.
Please do not infer what is not true. On all occasions I have used Poli-Seal on a LC red pad, one of the softest pads available. On the 60 day test, I made two (a couple) very light passes and the coating was all but removed.
you only need to put some PS on a hand applicator and work the area a small amount.
Do you consider that a hand applicator would be less aggressive than a LC red pad via DA? You don’t mention what type of applicator – could you please expand.
when applying PS as maintenence
You have often stated in various threads “If you want it to feel slicker top it with OCW or Poli-Seal”. Should users here, now assume that Poli-Seal should only ever be applied by hand and not by machine for maintenance?
What would you claim to be a safe period of time to apply Poli-Seal to an Opti-Coat’d vehicle?
I really think your posts hurt more than help
I would hope not. I simply reported the results of my testing in the message to Corey as I see Corey as someone who has demonstrated a desire to know more about the limitations of the products he is using. I would guess that there are also others here who have used or intend to use Opti-Coat who are equally interested.
