Thank you for your comments!
To answer your question I was getting an average of probably 7 or 8 passes.
That's interesting, sounds almost like the type of working time a product like XMT360 has. Does it start disappearing towards the end? I am definately interested in this stuff if it offers good cutting ability matched with a reasonable finish.
Any word on the types of abrasives used?
Holy Cow Corey, night and day difference between M105 and SYN 1. I originally thought M105 looked better than SYN1. :dunno: That's very cool that PB's is doing beta testing so they can correct problems like this. Thanks for the update! :dblthumb2:I used some SYN 1 again today during the preperation of new product review I was doing. I witnessed completely different behavior then last time I used. I was outside this time with higher temperatures and the humidity at 85%. It seems like the humidity and temperature has a huge effect on the SYN 1. Anyway under todays conditions it started dusting immediately and after 4 passes the polish was all gone. After going a couple cycles with it I switched to M105 to see what was what. On the panel I was working the 105 left a better finish then the SYN 1. I believe that differed from my first test in which they were extremely close but I thought SYN 1 had a better finish. This time arounf the 105 definetly had a better finish.
Heres a couple pics.
SYN 1 FIRST PASS
SYN 1 FIRST PASS
SYN 2ND PASS
SYN 1 AFTER IPA
(LOUSY PHOTO) SORRY
M105 AFTER IPA
M105 AFTER IPA
Thanks so much for posting the great review Dave! Your demonstration really showed what this stuff can do. :dblthumb2:
That paint was SMASHED!
I liked the fact that he used the product, experienced some side effects he did not like, and took actions to address them. I think some would just dismiss the product. I think the better detailers can adapt better to these variables.
I spent a bit of time with Syn 1 and my Flex L3403 Rotary last night and thought I'd share. The defects to be corrected were some light swirls and fine straight line sanding marks left over from a previous late-night detail session on a friends car.
As in my previous experiences with Syn 1 on my Flex 3401, I found the polish to do it's cutting and breakdown quickly. If you stop there you will have a corrected but "polish induced" marred finish, as if you just used a compound. Continuing to polish (while there is still a wet-film of product to provide lubrication) will refine the marring significantly. The defects were corrected quickly with just a white LC Flat Pad and left the paint in condition that 3M Ultrafine on a Blue LC Flat Pad had no problem with... which means Syn 1 finished quite well.
For a test I tried doing a section pass then moving to a new section of un-polished paint to see if the rest of the polish in the pad would provide the cut needed to remove the swirls *AFTER* the initial breakdown of abrasives. It did not. The area finished nicely, but the majority of swirls were still intact. This was just a test, confirming to me that there are some good aggressive diminishing abrasives in there, but it was not necessarily good technique
Over all I really like Syn 1, but I have two problems:
1- The dusting, I can deal with it by cleaning the pad often and being careful, but it's pretty bad.
2- Pad staining! I want to say horrible, horrible things! I just want my pad to be clean, please fix this before release Poorboy's, anything so the color is able to be easily rinsed out please!
For sure one bottle of Syn 1 can be considered sold upon release, if my two concerns are addressed before then it would be a bonus. Thanks Poorboy's and keep up the good work!
Thanks for your thorough testing, this is exactly what we need to know and how to explain to people the purpose of this product. We have not forgot about the product and both of your problems are being addressed. When we have a refined version ready we will offer some more samples to be tested here at AG online forum :xyxthumbs:
Hey, thanks! I appreciate the opportunity to help in the development of a product. Especially one from you guy's because I've had such great experiences with many of your products. REALLY LOOKING FORWARD TO A REFINED VERSION! I'd outright buy it no question if I didn't get in on a sample (along with the upcoming Air Freshener sample pack...? :drool:dblthumb2:
For the record, I like the fact that Syn 1 cuts quick and breaks down. Working in small sections, each one is done so fast I feel that if I was a seasoned pro and not "testing" and "hanging out" while I polish, the whole car could be corrected and ready for final polishing in record time.
Am I correct that Syn 1 has both a strong diminishing abrasive AND a fine non-diminishing abrasive? I thought I read it but can't find it... that's how I've been explaining it to friends...
Were working on something...... some more fine tuning before we send out the samples![]()
