swanicyouth
- Mar 3, 2011
- 9,388
Pinnacle.
Because it's the best.
I like the D115...for Rinseless I add 1 to 2 oz to 2 gallons of water and it works great as a Rinseless.
D114 for the obvious reason; no artificial shine or additional additives.
UWW+ because its dilution ratio is GREAT and works extremely well and is versatile. It also contains Polycharger.
That is way less than what the labeling specifies--which is ~6oz/gal and you are using .5-1oz/gal.
Although I still have some ONR and plenty of UWW+ conc., I have a gal. of D114 on the way.
Are you saying you need to use 12oz of D115 in a 2 gallon bucket to make a Rinseless Wash solution?
ONR is ever so slightly slicker, but DP left a slightly better finish and it doesn't turn my wash media black.
I don't know what I'm saying. Here's Mike Stoops saying take four gallons of water and pour in the whole gallon of D115, but if the car isn't that dirty, you only need to use half a gallon of D115: Mid-Year Introduction - D115 Rinse Free Express Wash & Wax . I thought the 20:1 dilution (what you mentioned above) was the rinseless dilution but looking back that seems to be a waterless dilution for not-so-dirty cars, but they say the "wax" will be diluted if you do that.
If you are good using this at a "normal" rinseless dilution then that is good info, because I could never understand how you were supposed to use D115 it looked crazy expensive any way you used it. :dunno:
