Rinseless Washing Question - How Wet Are Your Towels?
Marc08EX
I've been watching some videos lately that show how to do rinseless washing. Some of them show how little rinseless washing solution is left on the MF towel. They wring the towel out enough so that there's no liquid dripping. Is this the proper way?
I feel that there's not enough solution to lubricate the surface but I could be wrong. Do you guys do the same thing or do you have a lot of solution in the towel to the point it's dripping?
Thanks.
I slightly wring mine out. But I also spray the panel beforehand to "pre soak" it.
I presoak the panel with rinseless wash and use the towel straight from bucket.
Sometimes I find the towel is too heavy to move around on paint.
Thoroughly saturated for me. It'll be dripping across my garage floor to get to the car.
Too little liquid poses the greater risk, IMO.
Hi Marc,
Since it seems that there are so many variations of how to
perform rinse-less washing...Is there really a "proper" way?
So...IMHO:
Do the "rinse-less wash variation" that you feel will provide the best remediation, for the immediate task-at-hand's:
Level-of-Dirtiness.
I wring the towel out slightly but it's still dripping as I move the towel to the panel I'm working on. Even more so as I wipe the panel. It just makes a mess in the garage.
I just wondered if this is necessary.
Here's a video of Meguiar's shot in AG, on how to use D114.
https://www.youtube.com/watch?v=cICbdJocUI4
When you go to the 15 minute mark, it shows you how little solution they have on the towel.
Here's another video of a different manufacturer showing how little solution they're using to doing rinseless wash..
https://www.youtube.com/watch?v=v7dG0k0Aq-Q
I thoroughly presoak and slightly wring out my towels to the point they are barely dripping. I use really plush towels so there's still a lot of solution in the towel despite it not dripping. I also use a lot (12) of towels. I try not to get solution all over my garage floor. No problems with marring so far.
I use 2 bucket method and a mitt, also pre-soak.
:dblthumb2: I do the same. 2-Bucket 2 Grit Guard Wash mitt. I saturate each panel with RW in a spray bottle. It is the foaming type Spray bottle you can get at AGO for like $5. But IMO, this is a good method of RW.
My towels are still dripping slightly when I'm washing. I pre-soak all panels as well for added protection.
I've started to keep a little more juice in my towels. (Shameless IUDJ plug) I feel that it helps lubricate more. I like to feel a nice even glide when going over the paint.
Squeeze but not wring for initial wipe after pre-spraying panel until it's slightly dripping. My towels are wet, but just barely short of dripping. I like to use the green 600's from MFT for the first wipe, and then a fully wrung out MM 800 for follow up before drying.
1. I love videos like this. This car has like 1 day's worth of dirt on it. It looks clean before they even start. The guy keeps saying in the video how dirty it is. Lolz.
Do they have any clue what cars are like in the real world??? Not very confidence inspiring IMHO. Whatever is going on in this video - it's not washing a dirty car.
2. I'm not sure why you would start *any* type of wash on the middle of the vehicle.
3. Since RW and water are cheap - I say use as much as you want. What harm could a drippy wet towel do?? I use the towel as wet as I can get it.
4. Pressure washing (or even hosing off) the vehicle before you touch it will make a wash much safer than worrying about how much solution you use on your towel - regardless of what type of soap you use.
Now that I have the cr spotless I've been rinseing off my rinseless wash. That's funny. . Anyway my towels are pretty wet since I don't have to dry it. I'm already up to 8 on the meter, it's only been a month. Oh well still worth it
Speaking of towels, what do you guys recommend?
I was thinking of these towels just for RW but they may get too soaked and become difficult to use. I can just see them being heavy and wanting to come apart.
I looked into those. They do seem a little too heavy and cumbersome. I personally use Edgeless towels that are blue and named after a certain bird of prey...
I pre soak my car first. then I will do a 2 bucket with a mitt.
I like the 300-350 gram towels, pre soak,wash and dry with a waffle weave
4. Pressure washing (or even hosing off) the vehicle before you touch it will make a wash much safer than worrying about how much solution you use on your towel - regardless of what type of soap you use.[/QUOTE]
A nice thing about the invention of the rinse less wash is less water used, so your statement to "hose off" is going against the whole idea behind a rw imo.:)
Garry Dean has made a few videos where he uses a Paint gun with Rinseless wash solution in it to pre-soak the panels. He uses very high pressure in the gun (120 PSI if I remember correctly) so that he is blowing off most of the dirt before he wipes the panels down.
I think this is a very effective way of washing the car. In effect it acts as a pressure washer but using a lot less water.
Watch this video for details: https://www.youtube.com/watch?v=87ZLOYlSd-4
