steps you take using your flex 3401 to get finish back hologram free are.....Feed back please
Are you getting holo's with a DA![]()
No just after using rotary initial 1st cut with compound!
Finish down with a finer polish and you won't need a DA.
use 106FA or 85rd and guaranteed no holograms...
Who makes 106FA?
No holograms with 106 with rotary at all?
I too find this hard to believe...since it says it will remove 2500 grit sanding scratches
I would suspect it's how you're finishing off the compounding stage. Work it well and there's very little left to correct per se, just amp it up. Check out my video on using M105 and a yellow B & S pad. Dampen the pad for sure and work it long enough with VERY little product and you'll be amazed at how well it finishes down. M205 will do it for all but the softest of paints after that.
