Ok but if you have to tape every edge on the car that adds a lot of time to the buffing job. I very rarelly tape when I do a compound, and when I do is for a part that I know I will have no choice but to go over because of the shape of the pannel. Granted since I don't do it often, I am not good at taping and it does take me a lot more time than someone who tapes every job, but still... Also tape is very expensive, so that adds more expenses to the detail, which is not a good thing.
You guys seems really eager to prove that the rotary is superior. I would say it has advantages and disadvantages that probably puts it on par with a good DA. So if I was a new detailer, I could go either way and find success with either method. But after using a DA for 5 years, I feel like I have mastered it's use and don't really see a point to switch to something different that in the end will produce a similar result. But that's just me.
Also, you keep saying heat is not an issue you want to talk about, and burning through is not a problem... yet, that is pretty much the only reason people are not using rotaries.... or at least the main reason. So if you want to keep that out of the discussion, there is no discussion.
