BlackCoupe said:That is one of my complaints with Edge pads. I scored a FLAT surface because the plastic insert that goes between the top and bottom pads on the Edge, broke. To this day (a year later), those scoring marks are the only dings of any kind on my 2006 Black Lexus SC430. Having somebody give you a free replacement pad doesn't quite make up for that.
When I saw the damage in your pictures,I thought you had gone nuts with a rotary.
The Edge said:Can you please call to discuss? I just don't see how the pad was torn apart like that without some operator error and excessive pressure but I would like to know more about the situation.
trhland said:i would take that pad and punch it in the face!! shame on that pad!!!then throw it in the trash![]()
bad pad very bad!!
budman3 said:That was going to be my response as well. It seems, to me, that there was a lot of pressure put onto the pad and the pad wasn't rotating. After a long period of time like this, the PC "jiggled" side to side enough enough to cause the tear where the pad was resting on the lip. This happened to be right on the opening for the adaptor, which was a weak spot on the pad, compared to a few inches on either side. The tear happened without the user knowing it, and continued polishing when the plastic caused the damage on the lip. Again this is just my speculation about the problem... Hope they can get it fixed.
i was feeling a little goofykillrwheels@autogeek said:wow, never expected that from you .... a little pent up aggression this evening![]()
