SRConcepts
- May 6, 2013
- 255
Looks like they're available for pre-order on the AG site. Anyone take the plunge yet? :buffing:
Really really want the both of them---Still have to pay off some of the funds that got me started in this business. The second I pay off---gonna get both!
Probably be a few months before I can pull the trigger. But I am getting them.
I do have a pause---If I understand, you will need to get dedicated Mille pads and polisher. That to me is a concern.
Tom
Of course Rupes will want and prefer you to use it as a system, it just makes economic sense
and ofcourse Rupes and everyone at AG will only state you use it as a system stating best results, balance etc.
Mike Phillips said:If you're going to go with RUPES then go all in. That means, budget for and purchase a RUPES tool, the matching pads and the matching compounds and polishes.
AFTER you become experienced and skilled with their SYSTEM - then if you want to start experimenting with other pads and products go for it. And if you run into trouble maintaining pad rotation with NON-RUPES pads or if you experience VIBRATION with NON-RUPES pads then you know how to get out of this problem. Simple - go back to RUPES pads.
If you run into trouble with NON-RUPES compounds and polishes then simple - go back to RUPES compounds and polishes.
Found it.
At the bottom page, last paragraph.
https://www.autogeek.net/rupes-mille-gear-driven-polisher.html
Tom
For best results, it is recommended that the RUPES Mille Foam Pads and the corresponding RUPES Mille Chemicals are used with your RUPES LK900E Mille Gear Driven Polisher.
Tom
I think Rupes would sell even more polishers,pads,products if they actually encouraged using their stuff both as a system and without. Most detailers and hobbyists have dozens or hundreds of pads and gallons of other brands compounds and are deterred from buying a Rupes machine just as other brand machine owners are deterred from buying Rupes pads and polish. Rupes will really be just that much more awesome if they encouraged a more open system.
PS. I like your response Mike.
I feel like they do encourage it.
You have to consider that just after it was brought here, it was immediately modified, and encouraged use was with outside products. That concept took off like wildfire, which is great, but sort of a disservice to all of the research and engineering the manufacturer put into the liquids and pads.
