TTQ B4U
- Jan 20, 2016
- 5,504
- 70
- Thread starter
- #21
Had another detail where the Mille was my go-to unit. Tesla S correction involved both the Rupes UHS System and the Rupes Coarse Wool pads vs LC Blue and Purple wool. Here are my thoughts:
UHS SYstem.....Jury is out until after I use it on an upcoming BMW M5 that according to the owner just has mild swirls. We'll see. Here on the Tesla I did I was a bit put-off by it. Didn't cut nearly as much as I expected. I did the entire Passenger side with the Grey UHS Pads and their respective UHS product. Took about 6-7 passes at moderate speed to correct the vehicle to just about perfect. Not bad for a one-step but overall, not what I'm looking for. The other half I did with 3-4 passes of LC Blue/Purple wool with CarPro Clear Cut and got better correction in far less time. Especially since my arm speed can move up too. From there, it's a snap to make 2-3 quick passes with a white pad and polish. Sounds like the two should be a wash given two wipe-offs and still 6-7 total passes but it's not. I still moved faster with the two-step. and the wipe off of Essence is super easy.
Tomorrow I'm going to try a combo of pads including the UHS System but I also just picked up and recived a bottle of Sonax Cut & Finish. It supposidly cuts very well and finishes out the same. We'll see. Could be that I'm just ultra-spoiled using ClearCut and Wool. The only other downside to that combo that I'm hoping a one step will alleviate is the dusting. ClearCut doesn't dust as much when used with foam but on wool, just about anything dusts.
Another thing I tried with the Mille is the Rupes Coarse Wool Pad. It performed ok but here too, I won't likely be adding more than the two pads I have. LC Blue/Purple wool are EXCELLENT and not only cut better but finish out excellent too. They do reduce the smoothness of the Mille but it's still better than the Flex running those same pads and still, both combo's are easy for me to use.
Stay tuned for more.
