Kristopher1129
- Jan 3, 2011
- 2,861
I had a thread earlier explaining how I made an attempt to remove 2000 grit wet sanding scratches with the PC. I used MG105, the purple Megs pad, and the PC.
Needless to say...I went over it twice, and it didn't work. Busted out the Makita and BAM, gone. I really don't get how people do correction with the PC. I'm a Makita man! Here's the work I did earlier today...
Bad damage on the bumper
Damage on the passenger fender
Here's some shots with my hand just to show the size area I was working with
Taped off the edges, corners, and rubber
I don't know if this is just something I do...or if it's typical. But, I soak the sandpaper in warm water to soften it and prevent any possible dry sanding.
I know you're technically not supposed to wet sand in circular motions. But, I find it works better for areas with multiple scratches.
This was about the time I wanted to put the PC in the trash, ha. I used the Makita with MG105 to get out the 2000 grit scratches. Followed by MG205 and a blue foam finishing pad. This was after 205. I laid sealant down later on.
The finished bumper...
The finished fender. There was clearly a scratch too deep left. But everything else came out! I asked if the customer wanted me to repair the scratch...but she said if I got out all those other scratches she's more than happy.
Thumbs up? lolIm the MAN
