MisterSnoop
- Sep 15, 2020
- 2,292
- 545
I believe P&S said they had something to introduce so there's more to come.So do we think there will be any Day 2 product introductions, or did we see all the new stuff yesterday?
Yes, I agree that is the likely market and price, it's just I don't think the typical AutoZone customer is measuring their wash out, and that a bottle half the size at the same price as other soaps isn't going to sell well.I can see the hyper wash fitting on more shelves at AutoZone, etc in the smaller size. Price at more like $15 would seem more attractive.
I believe the general logic with a fabric softener solution is that it releases the static charge between the hair and carpet, thus making it easier to vacuum. I use a homemade FS solution when dealing with really bad hair. It helps but I wouldn't say its game changing. FWIW, I use the solution in combination with a Fureel and/or Lilly brush.Yeah, but what does that do? I mean how does that help get the hair out?
If it is 99% the same, just thinner, I would buy itVery excited to test out the new Hyper Wash!
I've been waiting for a tweak to that product for a LONG time. My only gripes were the viscosity, packaging, and smelling that same cherry scent for over a decade haha
Yes. Dr. G used to say that they put "salt" into most soaps (I think that's the chemist talking, I think he meant "a salt" as opposed to table salt) to thicken them, but Optimum Car Wash was thick because it had so many polymers in it, no thickening agents needed. Take that with a grain of salt.Which brings up the question, do manufacturers intentionally thicken soaps to make consumers think it makes it better somehow?
Certainly makes it easier to measure out.I don't give a rats @$$ if a soap is water thin in the bottle if it does what it needs to do, and in fact I prefer thinner soaps
Like more lubricity, or somehow thicker means more concentrated?
Use distilledI've considered diluting it like 1:1 with distilled water.
there's also chance of bacteria etc that could be an issue if it sits too long.Use distilled
@DFB was theorizing recently about the minerals in tap water breaking down pre-mixed soap solutions over time, like how I mix a gallon of foam cannon soap ahead of time
Probably something to be cautious of
Very good pointthere's also chance of bacteria etc that could be an issue if it sits too long.
Just watched a video featuring Yvan, apparently the production versions will "look a lot better".What were they thinking, it looks absolutely ridiculous.
I'm a Hyper Wash convert, but there were three elements I would have tweaked. The ultra thick consistency, the scent and an easier rinse-off.if Meguiar's only changed the scent of the original Hyper Wash, that might not go over well.
My hope is they made the formula less thick so they could compete with the current high-end shampoo options. Even at $19 for 32oz, it'd still be a good value compared to other options. They also need to ditch the "ready to use" marketing. Isn't all shampoo RTU? lol. Odd choice there imo
You should try Turtle Wax Hybrid Solutions Pure Wash if you can get it over there. I think you'll really like it.I'm a Hyper Wash convert, but there were three elements I would have tweaked. The ultra thick consistency, the scent and an easier rinse-off.
I agree with the RTU rubbish. The whole RTU Detailer line is aimed at retail sales instead of pro detailers.......................how do I put this.....................the RTU thing is about dumbing things down for the occasional user.
Interesting lineup.Koch Chemie
Hydro Plast Care is dilutable up to 4:1 to adjust shine. ~10 wk durability on Ceramic Effect Shampoo (berry almond scent). Ceramic Body/Rim due 1Q25. Mzr is like greenstar, same pH but safe for interiors. Pump sprayers are made by Kwaazar.
Hydro Plast Care
Water-Dilutable Plastic Care![]()
Hydro Plast Care
A water-dilutable plastic care concentrate with a subtle vanilla fragrance for refreshing plastic and rubber parts fo...www.koch-chemie.com
A water-dilutable plastic care concentrate with a subtle vanilla fragrance for refreshing plastic and rubber parts for the interior and exterior. Hydro Plast Care is free of solvents and the gloss level can be adjusted by diluting with water. Surfaces are protected against soiling and UV radiation while maintaining a factory finish.
Care shampoo with long-term sealing effect![]()
Ceramic Effect Shampoo is the care shampoo with sealing effect for hand washing. It cleans and seals surfaces for a l...www.koch-chemie.com
Ceramic Effect Shampoo is the care shampoo with sealing effect for hand washing. It cleans and seals surfaces for a long time in just one step. The preservation technology consists of a new combination of cleaning and care formulation and therefore creates a smooth, haptically soft and highly hydrophobic surface with a very good deep gloss. The quick and easy-to-use shampoo is ideal for surfaces that have already been coated, e.g. with Ceramic Body or Spray Sealant, and can increase the service life of the respective coating. With a pleasantly fresh berry-almond fragrance.
Ceramic Body Cb0.01
Ceramic sealing for painted vehicle surfaces![]()
Ceramic Body Cb0.01
Ceramic Body Cb0.01 is a ceramic coating and is used on painted bodywork surfaces to provide long-term protection. Th...www.koch-chemie.com
Ceramic Body Cb0.01 is a ceramic coating and is used on painted bodywork surfaces to provide long-term protection. The very thin protective layer is permanently bonded to the surface through a chemical reaction. Ceramic Body Cb0.01 creates a very good beading behavior (lotus effect). Thanks to the easy-to-clean properties, the treated surface can also be gently and easily cleaned by hand. The protective layer is retained even after the use of acidic and alkaline cleaning agents. The hardened ceramic seal protects the paintwork from environmental influences such as oxidation, salt, acids and insects for much longer. Ceramic Body Cb0.01 thus makes a significant contribution to maintaining or increasing the value of the vehicle. Expected durability can be upwards of 36 months, and layering (up to two coats) is possible. Please note the washing and care instructions.
Ceramic Rims Cr0.01
Ceramic Coating for painted rims![]()
Ceramic Rims Cr0.01
Ceramic Rims Cr0.01 is a ceramic coating that provides painted rims with long-lasting protection. The protective laye...www.koch-chemie.com
Ceramic Rims Cr0.01 is a ceramic coating that provides painted rims with long-lasting protection. The protective layer bonds permanently to the surface through a chemical reaction, creating a very good beading behaviour (lotus effect). Thanks to the easy-to-clean properties, the treated surface can also be cleaned gently and easily by hand washing. The protective layer remains intact even after the use of acidic and alkaline cleaners. The hardened ceramic sealant protects the rim's paintwork for much longer against environmental influences such as salt and brake dust build-up, making cleaning and maintenance easier. The service life is up to 12 months, depending on the maintenance. Ceramic Rims Cr0.01 can be double-coated. Please follow the washing and care instructions.
Allround Textile Sealant
Premium Textile Sealant![]()
Allround Textile Sealant protects all types of textiles against water, dirt and stains without impairing the look and...www.koch-chemie.com
Allround Textile Sealant protects all types of textiles against water, dirt and stains without impairing the look and feel. The water-based premium textile sealant is free from solvents and fluorocarbon resins. Allround Textile Sealant with its pleasant fresh fragrance is therefore suitable for indoor and outdoor textiles. The sealing components ensure an easy-to-clean effect and a long service life. Depending on the textile fiber, application purpose, wear and care, the durability is up to 24 months (comparable to up to 50 wash cycles at 30 degrees).
Mzr (Mehrzweckreiniger)
Interior & special cleaner![]()
Mehrzweckreiniger
Highly effective alkaline intensive cleaner for cars, industrial and building cleaning. Deep, thorough removal of oil...www.koch-chemie.com
Highly effective alkaline intensive cleaner for cars, industrial and building cleaning. Deep, thorough removal of oil, greases, ink, soot, nicotine and common road dirt. For plastics, textiles, upholstery, machinery, etc. Mehrzweckreiniger has an excellent dirt dissolving and carrying capacity. Provides a pleasant scent for the surroundings. With Daimler approval.
Pressure Sprayer alkaline 1,5l
The Pressure Sprayer Series was developed to enable process safety when working. Extremely robust 1.5L pressure pump sprayer for processing neutral and alkaline products. Thanks to the flexible suction hose, the device can also be used rotated up to 360°. With adjustable spray pattern and EPDM seals.![]()
The Pressure Sprayer Series was developed to enable process safety when working. Extremely robust 1.5L pressure pump ...www.koch-chemie.com
Pressure Sprayer acid 1,5l
The Pressure Sprayer Series was developed to enable process safety when working. Extremely robust 1.5L pressure pump sprayer for processing neutral and acidic products. The adjustable spray head means that even hard-to-reach areas can be reached. The adjustable nozzle can be used to vary between nebulization and jet. The special FPM seal is ideal for acidic media.![]()
Pressure Foam Sprayer 2l
The Pressure Sprayer Series was developed to enable process safety when working. Extremely robust 2L pressure pump sprayer for processing neutral and alkaline products. With interchangeable nozzles for little to a lot of foam and EPDM seals.![]()
The Pressure Sprayer Series was developed to enable process safety when working. Extremely robust 2L pressure pump sp...www.koch-chemie.com
Pro Pressure Sprayer acid 6l
The Pressure Sprayer Series was developed to enable process safety during work. Sprayer with high chemical resistance for the application of acidic mixtures. Ideal for cleaning surfaces, floors and walls. The special FPM seal is ideal for acidic media. The practical funnel makes filling easy. The lance is 50 cm long. Pressure: 3.5 bar![]()
The Pressure Sprayer Series was developed to enable process safety during work. Sprayer with high chemical resistance...www.koch-chemie.com
Pro Pressure Sprayer alkaline 6l
The Pressure Sprayer Series was developed to enable process safety when working. Sprayer with high chemical resistance for the application of alkaline mixtures. Ideal for cleaning surfaces, floors and walls. The special EPDM seal is ideal for alkaline media. The practical funnel makes filling easy. The lance is 50 cm long. Pressure: 3.5 bar![]()
The Pressure Sprayer Series was developed to enable process safety when working. Sprayer with high chemical resistanc...www.koch-chemie.com
It's available here, I'll have to look into it.You should try Turtle Wax Hybrid Solutions Pure Wash if you can get it over there. I think you'll really like it.
