cardaddy
- Nov 20, 2012
- 3,937
I've only used Meguiar's Ultimate Compound and Ultimate Polish. Both have worked well in removing minor to medium wash and dry scratches.
But will the UC be too much for nearly perfect paint?
Isn't the M105/M205 combo more abrasive than the UC/UP combo?
I see no need for anything more than UP at this stage. With perfect, or near perfect paint just a mild polish should keep you there.
As Aaron mentioned, there is a difference between working with DAT and SMAT products. Both work, and fine results can be optained from each. But... if you're used to using one with a certain pad combination, don't even THINK the other one works the same. I've no doubt that the end result with either can and will turn out fantastic but they both work totally different to get there.
Negative! The other way around!
Aaron, didn't you get that reversed?
