I agree with that is something off. Did you wait a little time between wipe down with N-914 and application? So it had time to evaporate before application. And did you shake the bottle with reload and was it a new bought? And how was the temperature and moisture when applyied? And have the bottle been frosen? Those are the things that comes to mind of what could be off. Other wise it's most remarkable that reload has gone.
Something obviously went wrong. I am not the most experienced, and am just starting down this really addicting road of finding out what works for me. The bottle of reload was brand new. Just got it. It may have gotten frozen in shipping. But I had it inside for days before applying. It was about 15 minutes after the 914 wipe that I did the reload. I did the PNS side first. It’s was only probably 45-50 degrees when I applied them. So maybe that has something to do with it.
But this is my point. I applied the PNS first with absolutely no issues at all. First! I don’t want products that are finicky. Ones that you have to apply while standing on one leg, at exactly 68 degrees, with a NW breeze of 15mph. Lol. I’m not trying to be difficult and I do hate when people post negative reviews because of their stupidity. But I am researching this stuff all the time now and trying to do the the proper steps. I really want to like the reload. I want to put Reload on one of my cars and PNS on the other.
I will try to wash and examine again today to figure out what may have happened.
Ok. I believe something may have happened to the product. I ordered during the recent freezing weather and it is my assumption that it froze and that did something to the product. Or I got a bad batch but I lean more towards the freezing component.
Here is a completely different car that is polished with Sonax 04-06 and then 3 separate IPA wipes. No 914. Straight IPA solution. 2 separate applications of Reload. Unfortunately the same failure. So something must have happened to the product.
Left passenger side has reload. Right side has McKees Hydro Blue.
So after the second application I want to not put a disparage Carpro reload or the company in any way. I think this is simply my first experience with dealing with product in which some external situation changed the characteristics of the product. I am going to contact customer service today and get the bottle switched out.
Thanks for all the input!
Sent from my XT1650 using Autogeekonline mobile app
Hi, i think its some problem of your application as well, you need to apply much more squirts over the surface , 1 mf wiping it on the surface sprayed and another one or dry side mf to wipe it off well, too thin layering will result shorter effect on the car.
latest Reload has no problem spraying direct on surface and wiping on and off.
