Reload is a polymer based spray product with 5% SiO2. It's also got a high solvent content in it. I'm not sure if it uses fluorine as a carrier for the SiO2 or not, but the durability is not as long as claimed. I use it mostly on rims and trim, and that's it. Once the stuff I have is gone, I wont' be buying anymore of it. It doesn't protect for that long, it's not that easy to use. It doesn't bead well, I think about 80 degree water contact angle or so, nothing too impressive. That being said, you should test the dirty release of the Reload side to truly see if it's still there or not. On my rims after an entire winter, it doesn't bead to save its life but the water release is excellent. One powerwash usually and Iron X doesn't really react after.
Well, I don't know anymore where this all stands?
But I can remember a video, probably posted by Corey from Carpro, where that smeary nasty Reload version wouldn't come off the paint with numerous wash downs with APC.
So, what has happened after that?
Ok, so let's take some things at face value here, and let's "De-Analize" ourselves for just a second.
So, Reload is a needed product after a application of CQuartz after it's applied to prevent water spotting while the coating goes through its final cure of a said to be 7 days.
Well, does it? Does it need Reload? Or what if I throw the bottle of Reload in the trash can, and say let's try something different?
How about a coat of Colly 845 on top? Why not?
Will Colly 845 hurt or remove CQuartz? Me, I doubt it.
Now all you fellas looking for the last little bit of beading and sheeting, and pounding your brains out over such, is it really that important?
You go with coatings largely for protection, don't you? Or am I missing something? Have we become so anal, that we're doing photo-shoots for beading, and run-off as a gauge to determine a product's worth? is that all there is, and is the only joy left in this game?
Next time I correct and coat a vehicle, I think it's high time I think off the grid, and make some unorthodox choices of products. And I just might not be wrong.
