looks like prev wax has to be removed by polish or cleaner to stick to paint - isn't it?
can wax cleaner eliminate clay step for lazy?
Now sorry if i ask something thats already been answered but, like the Meguiar's 5 step process the second step says to clean (paint cleaner) and the third step says to polish and then wax?
Mike Phillips said:This is key...
Saturation Application --> The First Application
This is a mostly unknown technique and that is to let the first application penetrate and soak into the paint for up to 24 hours before wiping the product off. The idea being to really apply the product wet and work it in really well and the walk away.
The idea is to allow the heavy concentration of oils to penetrate and seep into the paint for maximum saturation before removing the product and continuing with the process. In this case I finished applying the first application of #7 around 9:00 pm and then left the #7 to soak in until the next day. I started wiping the product off then next morning right about 10:00am.
Some will argue if this works or not buy my experience is that with a porous single stage paint it does in fact help. One thing for sure it can't hurt.
Paper Test for Capillary Action
If you place a few drops of #7 onto a piece of paper and then monitor it over a few days you will see the oils in the #7 migrate or seep away from the actual drop of product. It does this through capillary action and the same thing can work to your car's paints' advantage if it's a single stage lacquer or enamel paint.
I placed a few drops about the size of a nickel on a piece of standard printer paper around 3:00pm.
The next day I took these pictures at approximately 10:00am, (19 hours later), note how the oils in the drops of #7 have migrated outward via capillary action.
Feeder Oils penetrate or feed the paint
This same effect can take place in a single stage paint but not only will the oils travel horizontally, they will also travel vertically, that they will penetrate downward "into" your car's paint and this is where the term feeder oils comes from as the oils penetrate into or feed the paint. The result is they will condition the paint restoring some level of workability as compared to just working on old dry paint, and they will also bring out the full richness of color, something that will showcase the beauty of your car's paint.
I'm sure this has been asked many times so can someone send me a link to better understand what process should be taken? And should it be done every time? Again sorry I'm a detail oriented person that has to dissect everything. (that could be a good thing)rops:
Mike, I just tried the Pinnacle Lotion today after M205 and thought it left the paint slicker than just the M205 alone. I did however do an IPA wipedown after M205 and prior to the lotion....was that a wasted step? I also did another IPA after the lotion...probably another wasted step. LSP was 845 FWIW.
Our Pre-Wax Cleaner can be used with a DA. I'd suggest a polishing pad (a white Lake Country, which is what I use, as a point of reference).
We don't recommend Scratch Remover with a machine.
In both cases, there is a better choice in our consumer line for machine use - our 08616 Power Polish. It's made for use with a DA or rotary. Of course, AutoGeek stocks it:
Mothers Power Polish
Hope this helps.
Your thoughts on that? Will I accomplish anything other than playing?
Sorry one more thing, I found Meguiar's Mirror Glaze 205 and Pinnacle Paintwork Cleansing Lotion. Are these products good to use after claying and before sealing? I'd like to the cleaner and polish in one step before doing the wax or sealant.:work:
My plan is to wash, clay, use the new MF pads and polish for correction work followed by a MS wipe down then transition to Duragloss.
With DG, my plan was to use the 501 marine as a cleaner followed by the 601 topped with 105 then AW. Is all this in the right order or should there be something added or deleted?
In the original posting I just couldn't find when dealing with sealants where the correction work came in and how to successfully transition when using 2 different product lines.
Well
What they are
Paint Cleaners are typically liquid products that contain non-abrasive chemical cleaners and in some cases also mechanical abrasives of some type, suspended in a lubricating base.
What they do
Paint cleaners gently clean the surface and in so doing, remove any light oxidation, foreign impurities, surface staining, accumulated pore-embedding dirt and built-up road grime.
When to use them
Typically a paint cleaner is used before you apply your choice of wax or paint sealant. Specifically, a paint cleaner or pre-wax cleaner would be used after the car is washed and dried, and if the paint needs to be clayed, then after claying the paint with detailing clay but before applying a coat of wax or a paint sealant.
Order of Steps
- Wash and dry car.
- Inspect finish with your clean hand to check for above surface bonded contaminants.
- Clay paint - If above surface bonded contaminants are discovered then use detailing clay to clay paint, if paint is smooth an glassy feeling you can skip claying.
- Clean Paint – Use a Paint Cleaner to gently massage the paint and restore a clear, clean surface.
- Seal Paint – Use a premium quality wax or paint sealant.
Mike Phillips said:This would probably be better if it were it's own dedicated thread instead of tagging onto a "general" thread bout the benefits of using a light paint cleaner.
Yes you are right and thanks for the response. I understand.
