"The Good Stuff" Detail - Featuring the World's Finest
Nick McKees37
McKee's 37 Product Support
Every now and then you'll hear me refer to a product as "the good stuff." I often get PMs, emails, phone calls, and sometimes text messages (Who's handing out my number? Really?) asking me what defines a product as being the good stuff. Here is the definition that I've come up with.
The Good Stuff: Products that perform exceptionally well in their intended use. They don't cost an arm and a leg and are easy to use.
Happy? Okay, good. While Autogeek carries over 70 different brands (SEVENTY!), some products stand out more than others and earn the title of being called "the good stuff", by yours truly. I thought it would be fun to do a complete detail and feature nothing but "the good stuff."
Working at Autogeek certainly has it perks. One of them is being able to take advantage of the Show Car Garage on your day off and having access to a warehouse full of world-class car care products. Kid in a candy store? Not so much, because kids get sick from eating too much candy. Having a shiny car never hurt anyone.
So a couple Saturdays ago I arrived early to give a daily driver, a 2010 Honda Pilot, a little TLC. This is what awaited me:
It was in fairly good shape, but it could definitely use a little love from "the good stuff." The only thing that could have made the first step of this detail - washing the vehicle - a problem was the intense Florida sun. You see a problem, and I see a solution.
Let me introduce to you a little something called the Foamaster Foam Gun.
Not familiar with the Foam Gun and DP Xtreme Foam Formula Shampoo? Well, you should be, because these two products are probably the finest example of "the good stuff" when it comes to proper washing. The Foam Gun hooks up to a standard garden hose and when used in conjunction with DP Xtreme Foam Formula Shampoo, it produces mounds of thick suds that cling to your vehicle's surface, loosening dirt and road grime. The best part? It looks cool!
Here's a little tip when working with the Foam Gun: Put the water in the bottle before adding the soap. If you add the soap first, and then the water, you will be overwhelmed with suds. Only two to three ounces of DP Xtreme Foam Formula Shampoo is needed to completely wash an entire vehicle.
After adding the soap, screw the cap on and shake it like a polaroid picture! Now you're ready to begin washing.
Check out all that foam!
Not only does a Foam Gun enable you to wash the vehicle in less time, but it also lessens the likelihood of scratching or marring the finish when you rub the wash mitt across the surface. It's as simple as spraying the entire vehicle down with foam and letting it dwell for a couple minutes. By the time you actually rub your wash mitt across the surface, most of the dirt will be loosened.
After the foam had time to dwell on the surface for a couple minutes, I began washing with a Supreme Micro-Chenille Wash Mitt. For the price of this mitt, you will not find anything nicer. It's large, has super soft inner lining with an elastic cuff and the hundreds of microfiber fingers pamper your vehicle's delicate finish as you wash.
To clean the wheels and tires I used DP Wheel Cleaner. This wheel cleaner is safe on all wheel finishes and it also happens to be one of the best tire cleaners I've found. In most cases a really good wheel cleaner leaves much to be desired for tire cleaning, but that's not the case with DP Wheel Cleaner. Best of all? It doesn't contain a harsh chemical smell and won't burn your skin if contact occurs.
While the wheel cleaner was dwelling on the wheels, loosening brake dust and road grime, I scrubbed the tires with the Short Handle Tire & Wheel Brush. This brush features chemical resistant 2" bristles attached to a sturdy handle that is designed to take years of abuse.
This brush also works great for cleaning wheel wells!
The face of the wheels were cleaned with a Montana Boar's Hair Original Wheel Brush. This brush is the cat's meow for wheel brushes. It's constructed of natural boar's hair bristles that feature a feathered tip. This enables the brush to be a very effective cleaning tool while still being gentle on delicate surfaces.
The vehicle was dried using only the best microfiber drying towels available: Cobra Guzzlers. The Cobra Waffle Weave Guzzler features only the highest quality Korean microfiber that goes through a unique manufacturing process to ensure that it meets the quality standards of a Cobra towel. As part of this manufacturing process, the microfiber goes through a splitting machine to make what's called "ultra microfiber". Ultra microfiber is found in every Cobra Waffle Weave Guzzler drying towel because it's the softest, most plush type of microfiber available at any cost. No corners were cut in the design of the Waffle Weave Guzzler and that includes the borders, which are super soft so they won't scratch even the most delicate of painted finishes.
The Cobra Waffle Weave Guzzler is available in sizes Regular, Supreme, and Ultimate. To be a little more specific, the sizes are 16" x 24", 20" x 40" and 28" x 44".
After completely drying the vehicle and pulling it into Autogeek's Show Car Garage, it was time to polish the paint. The obvious choice for a polisher was the Flex XC3401 VRG. I don't even think the elusive title of being called "the good stuff" does this polisher justice. In order to fully comprehend why the Flex XC3401 is the best of the best, you must get your hands on one, plug it in, and polish some paint.
The Flex XC3401 is an awesome tool that has earned a reputation of being the Mercedes Benz of dual action polishers. But how do you make it better? Pair with Lake Country's newest creation - Hybrid Power Finish Pads and one of the best AIO's available, Blackfire Total Polish & Seal - and you have the best combination available short of Mario Andretti and a Formula One car.
What justifies Lake Country's Hybrid Power Finish pads as being considered "the good stuff?" Everything, for starters. I like to refer to them as Hydro-Tech pads on steroids. The new Hybrid Power Finish pads cut more and finish nicer than their open-cell counterparts and not only that, they tend to last longer too. The Hybrid Power Finish foam pads feature a 45 degree beveled edge that allows constant pressure across the surface. And because of the 5.5" backing material, they are self centering on the Flex XC3401 equipped with the factory backing plate.
If you've gotten your hands on any products in the new-for-2012 Blackfire line, you're well aware they provide a whiplash inducing shine that is rivaled by few. One of the new products for 2012 is Total Polish & Seal, a revolutionary all-in-one that contains Wet Diamond Polymers paired with an advanced blend of micro abrasives. If you can find an all-in-one that is easier to use than Blackfire Total Polish & Seal, buy it now.
As you'll recall, the hood of the Pilot being detailed had light water spots. Blackfire Total Polish & Seal paired with the Flex XC3401 and a Lake Country Hybrid Power Finish White Polishing pad made quick work of the water spots. This combination yielded a shine that would do justice for most people, but I knew it could be taken up another notch so the Pilot wouldn't only turn heads, but create whiplash too.
What did I have up my sleeve to further increase the gloss, slickness and protection already provided by Blackfire Total Polish & Seal? Blackfire Crystal Seal, better known as the 11 minute paint sealant.
Blackfire Crystal Seal is much more than a bottle packed full of specially blended polymers and gloss-enhancers. Blackfire Crystal Seal enables you to seal and protect virtually every surface of your vehicle’s exterior in minutes. What’s even better is how less is more, literally. Walk out to your garage with the bottle in one hand and an applicator in the other and you’re all set. Put the towels away as this spray sealant requires no buffing.
Blackfire Crystal Seal is quite possibly the easiest product you will ever lay your hands on. Not only does it induce whiplash by creating a reflective, hard-as-nails shine, but it also provides months of protection that can withstand the harshest of environments. Blackfire Crystal Seal protects and enhances painted surfaces, exterior trim, chrome bumpers, glass and wheels. Blackfire Crystal Seal provides a super-slick polymer barrier that virtually nothing can stick to.
Simply put, you will not find a product that provides this much protection in such a little amount of time required to apply it. Zip, zero, nadda.
After applying Blackfire Crystal Seal to virtually every surface of the Pilot including wheels, paint, glass and chrome trim, I treated the plastic and vinyl surfaces to a coat of 1Z Vinyl Rubber Care and Protectant. What makes this rubber and vinyl protect so good? For starters, it smells great, but that's beside the point. A little bit of 1Z Rubber Care and Protectant goes a long way to restoring a like-new finish to all exterior plastic, rubber and vinyl surfaces. It dries to the touch and will not streak or run when applied correctly.
This is one of those products where you use it once and wonder why you ever used anything else. Each application lasts several weeks and it's a great alternative for a customer that isn't seeking long-term protection on their vehicle's exterior trim (ie: Wolfgang Exterior Trim Sealant).
The wheel wells were dressed using Chemical Guys Bare Bones Undercarriage Spray. All you do is spray this product onto your wheel wells or undercarriage and within seconds you have a like-new appearance. For something that accomplishes so much at such a low cost of entry, Bare Bones Undercarriage Spray is tough to beat.
If you have a truck or SUV especially, treating the undercarriage and wheel wells with such a product makes a huge difference in the overall appearance.
The tire dressing that I always find myself going back to is DP Gloss Tire Gel. Like several other products that earn the classification of being called "the good stuff", DP Gloss Tire Gel goes above and beyond expectations in its overall performance. DP Gloss Tire Gel is composed of a thick, water-based gel formula that goes on thin and dries to the touch. It provides a low-gloss, natural look. Best part? It won't sling!
Remember when I showed you how to have fun polishing exhaust with P21S? Even after spending several hours on a detail, every time I use P21S Polishing Soap, I find myself grinning from ear to ear. Why? Because whoever came up with the idea for this product should win some type of award. It works so well and requires no thinking. Dampen the included coarse yellow sponge, create a lather with the soap and start polishing! It's almost like baking cookies with grandma, except it's not followed by a stomach ache and the aftertaste of skim milk.
Remember when you first read Mike Phillips' article, The Final Wipe – Tips for creating a streak-free, show car finish, and you thought "Hey, that's a great idea!" I thought the same thing, too, which is why it is now an essential step in every detail I perform. Although when applied correctly, Blackfire Crystal Seal doesn't leave any residue behind, it's never a bad idea to perform the final wipe just to ensure the vehicle is absolutely perfect before delivering it to the customer.
But which towel is the perfect towel for performing the final wipe? The thickest, most plush towel known to man - the Chinchilla! This towel is the cat's meow for plush microfiber towels. The thick pile removes any leftover polish and wax residue, or the finger prints of eager bystanders who must feel the need to touch the paint that you've spent hours massaging to perfection.
*Warning* You might want to stretch your back and neck muscles real quick as the shine I'm about to reveal is sure to create whiplash.
There you have it: a quick synopsis AND pictures of just some of the products I like to refer to as "the good stuff." These products are quintessential examples of why car care and detailing is this much fun.
Stay tuned for more, as there are several other products - interior and exterior - that are also considered to be "the good stuff." What you read here is just the tip of the ice berg. :)
Hey Nick,
This is a great thread for everyone to see just how many steps and the work it takes to detail a car the right way. Just about anyone can wash a car but this goes far beyond washing and the end result is dripping. One of the nicest colors to make pop!! :props:
Great selection of products
Superb photos
Gorgeous weather...
Amazing write-up Nick! Reading your articles is like reading a well written magazine article. I also like the fact that you're showing how each product works.
Nick, that's really a cool write up, I enjoyed reading it a lot. My neck still hurts from the whiplash pics, ha-ha!
Looking awesome Nick. Who are these bandit bystanders you speak of?.... We want names. LOL
Looking good Nick! The pipes have some very sharp looking exhaust tips.
I do like the denser style mf wash mitts.
Lets just say one of them has a name that starts with an M and ends with eghan. :D
Shiny exhaust tips is the icing on the cake for a detail. It's something that's often overlooked. :)
Nice job, Nick. :props:
There was obviously some water spotting, but I didn't see any swirls??
What speed did you use with the 3401?
There were some light swirls, but nothing too obvious. Blackfire Total Polish & Seal took care of them.
I used speed 4 on the 3401. :dblthumb2:
ive been wanting to try that polishing soap, i have clear coated chrome wheels but my exhaust is constantly dirty and it never stays clean, this seems like it would clean it much easier than the polishes ive been using. Great write up!!!
Ok, question. When using a foam gun, do you still rinse your mitt off after each panel in a rinse bucket with a grit guard? Do you still need a wash bucket?
Seeing this brings up a question I've had for some time about foaming. I see alot of pics of people doing this in direct sunlight. Doesn't this evaporate or streak from drying before you can get your wash mit over the whole car and rinsed ? Just something I've been curious about for a bit. Thanks
