That's a very good point that I've thought about. However, some people have been able to get good correction from the "cheapos". Again, if I don't like it, I'll use it to spin dry my pads, and I'll try your Makita!!! haha :dblthumb2:The only question I have is that are you really seeing how a real rotary works by testing out an ultra cheap machine ? You might not like that cheap one but you might like the better Makita .
Well, tried the Harbor Freight rotary, what a pile of sh1t!!!
If I put any type of pressure on it, the pad slowed down!!! Is that normal for a rotary?
It's a GREAT tool for spinning the water out of my pads, though. That's good enough in itself for me.
It boggs down easily with 5.5" pads.When you apply downward pressure to a rotary, if you're using a large pad, anything 7" and larger it is normal for the motor to bog down as you're putting a load on the tool.
With just a 5.5" pad, that's a bad sign...It boggs down easily with 5.5" pads.
The machine controls you instead of you controlling it, at lest for a newbie.
Just a heads up as far as a rotary since your new to using one and i understand buying a cheap one just try it out is a good thing.Don't get to comfortable using the cheap one .You mentioned how the rotary controls you wait until you buy one like a Makita or a De Walt then you will really see how they try to control you .Also depending on what pads,Wool,etc,even the car your working makes the rotary act differently but once you get the feel of using it the job goes a lot easier.It boggs down easily with 5.5" pads.
Anyhow, a rotary sure has a much different feel than a DA. The machine controls you instead of you controlling it, at lest for a newbie. All of this is expected, though. I'm going to practice on junk panels and I'm sure it will get a bit easier to control each time.
Cool. Thanks for the heads up. A buddy of mine has a Makita coming in a couple of days and I'm definitely going to try it. I've told myself that I need to have patience, this is definitely something that takes time and practice to learn. I have a different(better) mindset than I did a couple days ago..lol. :buffing: :xyxthumbs:Just a heads up as far as a rotary since your new to using one and i understand buying a cheap one just try it out is a good thing.Don't get to comfortable using the cheap one .You mentioned how the rotary controls you wait until you buy one like a Makita or a De Walt then you will really see how they try to control you .Also depending on what pads,Wool,etc,even the car your working makes the rotary act differently but once you get the feel of using it the job goes a lot easier.
Well, tried the Harbor Freight rotary, what a pile of sh1t!!! :laughing: If I put any type of pressure on it, the pad slowed down!!! Is that normal for a rotary? It's a GREAT tool for spinning the water out of my pads, though. That's good enough in itself for me.
Didn't know this. Thanks!I would suggest getting a wool pad to learn with because they just glide along and this way you can get a feel for the rotary. Another pad that works very well with the rotary without "walking" you around is the Kompressor pads.
Did you not read my posts?
I did. I never disagreed with you. As I said earlier, I bought it with the intention, if it sucked, I'll use it to spin water out of my pads. I was a win-win situation for me. :xyxthumbs:Did you not read my posts?
Would you say wool or kompressor pads glide easier over the surface?LOL, you always get what you pay for.
I took your (among others) advice to stay away from the cheapos, but if I find one for $29.99 like O.C.D did I doubt I could pass it up, just to use it for cleaning/drying pads. I looked a a couple pawnshops yesterday and saw old beat up Makita's for $200-$250 and they wouldn't bargain! Uhhh... if I'm gonna pay full price I want new LOL.
Wow... for old beat up ones, when you could just get a new one here for $225 shipped! I would just get a new one man.... you will always use it down the road and knowing that you bought it new is just a good feeling. You don't want anything potentially breaking down on ya!
