Fast gloss, power finish and super finish are the only three Menzerna products you need. SF4500 for the softer clears.
So either of these combos would do me good right?
Wolfgang Uber Compound(one-step?) & Total Swirl Remover
or
Menzerna PF2500(one step?) & SF2500(Swirl remover, finishing)
or
Never tried Wolfgang, but their Über compound would be comparable with Menzerna fast gloss and total swirl remover sounds like Menzerna PO85RD3.02, IE Menzerna "SIP", and their finishing glaze should be something like Menzerna PO106FA Super finish.
Menzerna Power finish, PF2500 is a great polish, but it's not a compound. It can do some good cutting if used with a cutting wool pad and rotary - but it's a polish.
A good two step punch would be FG400 followed with PF2500 or SF4000, it all depends on what kind of paints and machines you are using. FG400 was designed to be used in a two stepper and therfore can finish out so nice that you don't need a heavy polish. As said above, never tried Wolfgang so I can't comment on those, but since they are made by Menzerna, I can only guess.
^glad to hear you got some cut with PF2500 w/ H20 Tangerine pads. I got door dinged with some scratches for the first time on my new car this weekend and this is the first area of correction I need. I have PF2500, SF4500, and just bough m105 in case. Do you think PF2500 will get these scratches out? The deepest of the scratches I can feel with my finger nail ever so slightly, but it doesn't grab and hang on to my nail. I'm not sure if its just white since the salt got ground into the paint, or if it got through the base coat. BTW, this is Toyota paint, so I think it is soft? What do you guys think?
WG Uber = FG400
WG TSR = SI1500 (TSR has more cut less gloss than SF2500, and SF2500 has less cut more gloss than TSR)
WG Finishing Glaze = SF4000
Here's and updated chart:
UPDATED: Autopia Car Care Polish Comparison Chart - Autopia Forums - Auto Detailing & Car Care Discussion Forum
Oh yea, when I came out of the store and saw the salt all smeared around my stomach dropped and I said "please only let it be brushed by someone". Nope, I'm assuming a door got it. That sucks. I made it 1 year and 3 months w/o a door ding.That sucks man! Hopefully the 2500 knocks it out, I believe it will, if not M105 should since it your fingernail doesn't grab.
Thanks for that chart man! I am going to see what the Lightning Deal is today, and then make my decision. I appreciate everyone`s input. Looking at the chart, the Wolfgang seems easier as there is only 4 choices.
FG400 finishes down nicely and very easy to use.
Oh man really? I don't need a lot of cut though, only on that door ding. My finish has never had swirls instilled in it, but if I use PF2500 then I don't want to have it turn out badly. If I go over the PF2500 with SF4500 will that clear the finish up?I really do not see a place for PF2500. I have a nearly new quart of it that I would gladly sell to anyone.
From my experience, FG400 cuts more than PF2500 and finishes better. If you require less cut, then use FG400 with a polishing pad.
For instance, on Sat, I tested PF2500/LC Orange, FG400/Rupes Yellow foam and FG400/Meguiars MF Cutting Disc.
The FG400/Rupes yellow foam combination cut more than PF2500/LC Orange, and also finished out with noticeably less haze. Even the FG400/MF Cutting Disc combination only finished slightly worse than the PF2500 combination.
I think some will come out, mainly the scrapes, but right where the door impacted my door they may not. Too late, I already have SF4500 :xyxthumbs:Those scratches are deep. I doubt that anything other than wetsanding or a rotary/wool/M101 is going to get them out.
I wouldn't waste your time and the surrounding clearcoat, tbh. Just wipe off any paint transfer with Laquer thinner and run over it real quick with a finishing polish.
I would not get SF4500. Get SF4000. It will finish the same on most paint systems and will be a far more versatile product.
