Ultima Paint Prep Plus: What did I do wrong?
Kurt_s
I decided to prep my paint today with UPPP in preparation of using UPGP for the first time. I didn't work anything like I expected.
I tried applying UPPP to the hood first with both a tangerine HT pad and a flat white pad with a PCXP. Maybe I used too much? Maybe I didn't work it long enough? I let it haze as instructed but it would come off with a indigo MF towel. Instead of adding gloss to the paint, it made the paint look hazy and lightly marred It was about 60-65F in the garage which I assume is ok.
I ended up using M205 for the first time (pretty good stuff) to polish the hood and used Fuzion instead on the car. I really wanted to try UPGP but if I need to use UPPP first, this could be problematic.
So, what did I do wrong with UPPP?
You don't have to use uppp first but it's beneficial. You can use pgp over 205 if you wipe it down with the Ultima detail spray first. As to your problem removing it sounds like you used too much and didn't work it long enough. When worked well it removes really easy.
I was thinking that might be the case. I've used other prewax cleaners by hand and never saw anything like this before. Any secrets to amount of UPPP to apply to a 5.5" white or blue pad for a given section of paint? How long do I need to work it? Why Ultima detail spray vs another QD? Thanks!
A couple of pea sized drops will cover a 2x2 area. Work it til it almost dissipates and allow to dry. My success has been with finishing the entire car and the removing. The Ultima detail spray *seems* to aid with durability after using 205.
Hey Kurt,
I've never used this product before but your description does sound like you might have used a little too much. The left over haze also sounds like the product may have needed to dry more and at that temperature it may not have been dry enough.
I remember Corey doing a couple of write-ups on Ultima products and saying how little needed to be used.
Kurt, man sucks to hear that buddy. I'm shocked you had that issue. My paint has always been super glossy after using UPPP. I use a crimson or grey pad.
I don't know why that happened to you. It has always come off extremely easy for me. My only assumptin can be that you used too much but maybe there is some other strange factor in place.
Kurt, I usually apply it by hand. It doesnt have too much cut, If the 205 looks good, apply UPGP over it. Spray the applicator twice to prime it and then wipe on a panel. Spray once for each additional panel. It will likely streak, but avoid temptation to wipe off. Next day it will look great!
Not sure I'd like to use a paint cleaner with ANY cut. When it comes to a paint prep cleaner, I prefer to use chemical based products with a finishing pad.
Thanks for the suggestions. How much more do I add after the first 2x2 section? Do you clean the pad after each 2x2 section or major area like the hood?
Hey Kurt,
I had the halogens in the garage and I was working in short sleeves so it wasn't too cold. The product completely hazed like a wax but wouldn't wipe off. It was stuck to the paint like M105 when it gets wet. Cement. In some spots, the paint actually looked like it was marred. I must have used too much and maybe should have worked it longer and spread it over a larger area.
I first used a tangerine HT to help remove some minor swirls and used about 2 quarter sized dabs which I spread around the pad to prime it. It would not come up competely with an indigo MF and some spots actually looked like they were marred but I think it was just the stuff stuck to the paint. I was afraid that it was the HT pad since it was the first time that I tried it.
Next, I polished the entire hood with M205 and a white pad to make sure the paint was clean and clear. M205 is a pretty nice polish. I need to play with it some more versus Opt Spray and WG FG3.0.
I then tried a brand new white pad with the UPPP applying 2-3 pea sized dabs to 1/2 the hood. Again it stuck to the hood and would not release. Totally weird and I gave up.
I then repolished the entire hood with M205. Since the manufacturer recommends UPPP to improve durability, I gave up on UPGP last night. Bummer, you and Jim really like the sealant.
I finally just laid down another coat of Fuzion since it takes so little time apply, durability is great and I like the look. I did get some UTTG some of the black plastic trim.
I will run with Fuzion for the next month or so. I may try the hand method next time. At least the car is in good shape for the next month or two. Would you use an IPA or MS wipedown after M205 and before UPGP?
So you don't buff it out the streak like Opti-Seal?
I do the same. No cut pad for my finishing with UPPP since I've started using a machine.
However about a year and a half ago I did use the enclosed hand applicator I was sent and did the entire car with it. That hand applicator has some cut to it like Jim said but still came out beautiful and as glossy as could be.
I originally planned to use a blue glaze pad and the directions said minor swirl removal. I wanted to see what it would remove with a tangerine HT. I had issues with a white polishing pad too.
In the past, I always applied paint cleaners by hand with a foam pad. Might just go back to old school since I am only trying to clean and remove old sealant/wax/residue but a DA should make this super easy.
Gotta try new things and see what happens. I am not encouraged by UPPP but I will chalk it up to using too much product and not working it long enough.
I'm perplexed. Must be not working it long enough? I'm not sure. How long did you work it?
My gut makes me feel like it's some kind of anomaly we aren't thinking of.
Next time you try it out do a test square and mess with it to see if it works.
FYI: I have so little issue removing the UPPP I have done the entire Sky inside my garage with it and buffed it off after the car was done. Something seems strange. Could it be a bad batch? Maybe give Sam L. a call.
I initally made maybe ~3 passes as I wanted to see if it would remove any minor defects with the tangerine HT. Not much cut at all. I was running 5-6 on the DA to keep the head rotating.
Then I tried using it like a chemical cleaner and made 1 horizontal and 1 vertical pass to overlap a 2x2 section. I noticed that the pad would not rotate at speed 4 unless I used almost no pressure, so set the speed at 5. The M205 pad rotated easier at 4 and 5 settings. Wiped the pad face with a terry towel to remove any build up between sections and added 1 or 2 small dabs. I even tried moving to another section without adding addition product. Same issue. I also tried 2 different MF towels.
I used CG Citrus Wash and Gloss to remove old wax at the 1oz to gallon concentration. It stripped most everything (except the UTTG on some trim around the rear deck). The paint no longer beaded so I'm pretty sure it removed the old Fuzion. Since I tried UPPP before and after M205 with similar results, I don't think it was the CWG.
Maybe I will call Sam. I know how much you like the Ultima products so I am happy to work through the learning process. It's got to be something really simple.
What year, make, model and color is the vehicle you're working on?
Hmm, haven't worked on that particular paint before. Have you found the paint to be particularly soft at all?
I've found that very soft paints can be a pain to work with when it comes to oils in certain polishes or waxes/sealants. My S2k along with some other soft paints I've worked on seem to hate certain products, while others are a breeze. I've never had this issue on harder paints so it's some food for thought.
I don't find it particularly soft. It can be a PITA to correct for that matter. I just left a phone message at Ultima asking for help and they are supposed to call back. I'll post what they recommend.
I spoke with Sam and Gary at Ultima today. I have them stumped too. I will send an ounce to them for testing. I'm pretty sure that it is me not the product.
I did learn that I could use either their detail spray or UWW+ after using a polish like M205 to remove any residual oils or polish before using UPGP without significant issue. If I had known that I could use UWW+ last night, I would have tried the UPGP instead of Fuzion.
Again, I will post a follow-up after I hear back from Ultima.
Hi everyone,
I'm just wondering if anyone has followed up on this thread. I did some scratch repair today on the hood of my Acura TL. After the repair, I wanted to re-apply Ultima Paint Guard Plus, so I cleaned the paint using Ultima Paint Prep Plus.
Before I get too far in this, I should mention my conditions. I live in Wisconsin, working inside my heated garage at 65 deg.
I hand applied using the supplied orange foam pad and worked the product quite hard, wanting to take care of a few minor swirls. After 90 minutes of drying time, removed the UPPP with a thick microfiber towel and had the same problem as the original poster. Although the product seemed to be dry, I couldn't remove it all, leaving smears in areas of the hood. The car is black so every little streak shows up, but I could not get rid of those smears no matter how hard I rubbed.
I went ahead and applied a coat of UPGP anyway, hoping it might blend the smearing, but no dice. Still very apparent even after the sealant. As someone else posted, I tried cleaning the affected areas with detail spray (UWW+) without success.
So, I'm trying this solution as we speak. I just reapplied UPPP and went extremely thin (2 pea sized dabs for the entire hood). It is noticeably thinner this time. Have also jacked up the heat to 72-deg and will check in an hour to see if it has hazed over. I'll report back on my results.
In the meantime, if some of you with experience with UPPP would care to advise, I'd be very interested and appreciative.
Best,
Steve
FOLLOW UP: Just buffed off the UPPP and while better, still not perfect, this after a full hour drying time at 72 deg. Again, this application was REALLY thin. Still had some minor streaking in areas.
Is this long drying time normal for this product? I love using UPGP but might not want to continue using UPPP if this is the case.
Thoughts? Anybody?
Thanks.
