WRAPT C5Z06
- Nov 12, 2009
- 12,615
With polish, if the clear coat is harder, most of the time you have to use a more aggressive polish or pad to correct the paint. With clay bars, can the same logic be used for removing contamination?
Good point. I just got a little too excited yesterday.(Dont take this the wrong way, but you should just post your questions in the claybar thread that you already have. This has been your 3rd thread about claybars and it would be alot better to ask a question in those threads instead of cluttering the forums.)
Yet again, Mr. Mike Phillips makes comes through with a perfect, easy to understand answer.2 comments...
When removing above surface bonded contaminants the softness or hardness of the paint doesn't matter as it relates to the actual removal of the above surface bonded contaminants as the removal process is about abrading the contaminants, not the paint itself.
Will claying remove sealants and waxes? I have felt it would but would like to know from a pro.
Read the thread, just a lot of back and forth over the subject. Still leaves me with no absolute answer.There is an excellent thread on Meguiar's Online about this: Does Claying Really Remove Wax? - Car Care Forums: Meguiar's Online
When you rub a clay bar with pressure over a waxed, painted surface are you adding wax?
I stand by my original conclusion which is I'm sure there is some wax removal where bonded contaminants were cleaned from the surface, but not where the clay traveled over already smooth surface.
Mike
Normal Conditions = You're not using an aggressive formula clay bar for Professionals and you're using common sense when you move the clay over the paint, not Caveman Technique.
I just replied to that thread and I'll stand by my comment made in post #11 on page 2 and my new post #63 on page 7
:laughing:
My first answer in that thread is a form of presenting ideas in their extreme which helps sometimes on discussion forums because there's always a segment of members that take everything to extremes...
So to quote myself,
That's a reply to this question,
And while everyone can discuss and disect the idea into enternety, here's was my reply to my good friend Mikejl's conclusion,
Makes sense.
Of course the huge variables here are,
I'm a big fan of keeping things simple but I notice the trend for at least a segment of online enthusiasts is to take things that are very simple and over complicate them.
- Downward pressure
- Number of passes
- Thoroughness of claying over each square inch being clayed
- Aggressiveness of the clay
- Lubricity of the clay lube
Scenario I
If you use a medium to aggressive clay bar with firm downward pressure for a dozen passes over a section about 12" square and you do this thoroughly with a normal spray detailer, say Quik Detailer, at a minimum the wax or sealant coating will be compromised and if it's my car it will be compromised enough that I"m going to add a fresh coat of wax or paint sealant.
Scenario II
If you use an Ultra Fine Clay with very light pressure for just a few passes to say you made a few passes over a section about 12" square using a high lubricity detailer like Last Touch NOT diluted, then at a minimum, the wax or paint sealant will be compromised enough that afterwards I'm going to re-apply a fresh coat of wax or paint sealant to that area.
The argument could be made in the last scenario that not enough wax or paint sealant would be removed to make a difference and if that's what a person thinks then I'm okay with that, detailing is so subjective.
Where the rubber meets the road...
But in either scenario, if it's my car that's being clayed, I'm going to re-apply a fresh coat of wax or paint sealant and that's the only scenario that matters... at least to me...
:laughing:
Another aspect of detailing discussion forums is that members will discuss and dissect a topic to death until everyone has their say and everyone's made up their mind. That's what makes a public discussion forum a public discussion forum.
Cyberfun in the Cyberworld!
