Rsurfer
- Jan 26, 2007
- 14,160
- 26
No when I first got it I skipped oiling anything.
Maybe that's the problem.
Yeah, well, I'm trying to find the mechanism buy which this "burning out" works. I understand the refrigeration scenario (and other motors which use a start capacitor), but the power tool one doesn't make sense to me. And the fact that I can't easily find an explanation for it on the internet tells me that it's an old wive's tale. However, I am not discounting your personal experiences.
Powerhouse Distributing is the official service center for Flex. They are located in Omaha.
Bob Eichelberg, the president of FLEX North America, lives in the Omaha area as well (Elkhorn).
Ok so if I decided to buy a Flex (and I am really tempted) what would be the steps to take to prevent overheating?
So good quality extension cord for sure, but after that?
Is there any lubrication that needs to be done before use?
What backing plate to use for 5.5" pads?
Anything else I need to know about using a Flex 3401?
Lubricating the felt ring is no longer required nor recommended.
Actually it is recommended if you apply a lot of pressure or are on a slight angle once in a while. It was also stated that it does not hurt to do it so why not take the precaution? The issue of the burnt backing plates a few years back was stopped by taking this precaution.
If it doesn't hurt then why not do it to prevent something from happening?
Page 4 post #37 on downCould you please post the link to this official recommendation from FLEX?
Mike has since said that lubricating the felt is no longer required nor recommended as they updated the design.
what has been updated and does it not use the white felt ring anymore?
I can't say for certain, but I believe it was modified in such a way that the BP doesn't ride along the felt ring all the time.
Originally Posted by Rsurfer
I just took apart the backing plate to the 3401 and I can see where the bp is touching the felt ring. Without the felt ring the plastic bp will rub on the metal housing. Without lube the felt ring would be rubbing the plastic dry and would create heat.
Originally Posted by SonOfOC
I don't think so, that's not how I read it. Mike P was only showing you how if you wanted to.
Mike Phillips and Bob Eichelberg from Flex says "No reason to lubricate the felt ring".
Please read
Originally Posted by MinnBobber
don't know how to do a link--can someone give instructions, but here is where I saw it and
someone can do a link please.
Post was 3/29/11 by Top Banana titled "Oiling the Flex 3401 Felt Ring".
On page 3 of that thread, Mike responds on 4/19/2012:
Re: Oiling the Flex 3401 felt ring
At some point in time it is believed that some number of people had issues related to the Flex 3401.
Someone, not me, came up with the solution to lubricate the felt ring.
I spoke with Bob Eichelberg last week about this and he said [HIGHLIGHT]there is no reason to lubricate the felt ring and no one needs to lubricate the felt ring.[/HIGHLIGHT]
My article was merely for the purposes of showing people how to do it
