Velocitybts
- Apr 11, 2013
- 178
The below scenario I think it would be interesting to see how Mike/detailers would go about correcting the issue, or what can be done or not done.
1. A car (Aston Martin DB9) is paint corrected to perfection (20hrs spent) then coated with a coating such as CQuartz, 22PLE, Gyeon, Modesta etc.... 3 weeks later the customer comes back in and says there are water spots that appear below the coating. The customer says its not always visible but from certain angles they can see them and its driving them crazy.
a. you know the paint was perfect before the coating. So you inspect the vehicle, and sure enough at certain angles you can see the water spots, AND they are below the coating or in it, but not on the surface.
b. you need to make the customer happy so what are the next steps and what are the issues you will have?
Water Spots----- you know they are likely beneath the coating, however after you have washed the car, and brought the car inside and you are ready to start trying to remove the coating, you can no longer see any of the water spots!!!!
a. So, you pull the car back outside and leave it sitting to think about what the next step is while working a current customers car inside.
b. while taking a break you walk outside and notice----sure enough there are the water spots showing up again.
c. you immediately pull the car inside, let it cool down, and when using your swirl light again on it after it is cool you cannot find the spots anymore.
A> List out what or how or why you think the water spots are showing sometimes but not others
B> What is your next step?
C> The car has a coating on it, how do you know when you have removed the coating without taking off more clear coat?
This ends up being very complex as to why and how this situation can arise, and leaves the business in a pickle of what to do. I hope this will be interesting to see how Mike would handle it, explain how or why this is happening, and what others think of how to approach this.
In the end, I hope the readers learn a lot more about Paint (clear coat) and how it reacts with heat, and how to handle situations dealing with Coatings after the fact!!!!!
