That's why, IMO, it's a good idea to stay abreast
of the latest info that's provided on this, and other
detailing forums, by Manufacturers and forum Members.
Sometimes that info includes what's "on the label".
________________________________________________
Here are some updates to the dilution ratios
of D114 and D115 that you may have missed:
Re: Questions about D114 RFEW
"We recommend using D114 as a rinseless wash with a dilution ratio of 1 ounce to two gallons of water. 1:256
If you're going to use it as a waterless wash you should at least double that ratio (1 ounce per gallon. 1:128).
As a clay lube, the standard dilution ratio (1:256)
works quite well".
Michael Stoops
Product & Training Specialist | Meguiar's Inc.
(800) 854-8073 xt 3875
[email protected]
"We should clarify something, however, regarding dilution ratios: recommended dilution ratio is 1 ounce of D114 to two gallons of water.
The instructions on the initial run of labels state a 1 ounce per gallon dilution ratio, but we are adjusting that down for routine use".
Michael Stoops
Senior Global Product & Training Specialist | Meguiar's Inc.
