Waterless wash / No Rinse
You can even use 2BM with rinseless, which is my preferred method.
I'd charge the same as you would for any other wash, why sell yourself short?
I've been using both D114 and ONR on my cars and have had no problems with scratches/marring. If you're using a clean towel surface for each wipe down, the proper dilution ratio, and aren't working with a heavily contaminated vehicle, you should be okay. As stated earlier, using the right dilution will reduce streaking and makes the overall process easier and faster. Sometimes I'll rinse my car down with the pressure washer first and then bring it in the garage before rinseless washing. Doing this gets rid of quite a bit of the dirt before I even make physical contact with the paint. I still use the 2 bucket method for when my cars are fairly dirty and I don't feel comfortable doing a rinseless wash on. I'd say give it a shot on a panel or two and see how you like it.
This is my thinking as well.
It was alittle different at first, just make sure you use quality towels and have a bunch at your disposal. Also, I do wheels/rims last because I use the excess rinseless solution from washing the paint. I just keep the designated wheel MFs out of the bucket until I am done with the paint. And I remove the extra unused paint designated MFs before putting the wheel ones in.
How many people use a rinse-less and/or waterless wash on a regular basis? Do you only use it as a last resort? I still find it hard to believe that using one of those wash methods doesn't produce swirls and/or scratches. I purchased ONRW hoping I could get past my apprehensions about using it to wash my car, but I cant. Have any of you experienced any problems with scratches, etc from using it? Thanks
I haven't used a hose in 2 years. Rinsless is all I do because most of my details are indoors. As others have mentioned if you use the correct technique and you have good wash media you will be fine. I use the GDWM and it works really well, it's safe and fast.
