I've been using both D114 and ONR on my cars and have had no problems with scratches/marring. If you're using a clean towel surface for each wipe down, the proper dilution ratio, and aren't working with a heavily contaminated vehicle, you should be okay. As stated earlier, using the right dilution will reduce streaking and makes the overall process easier and faster. Sometimes I'll rinse my car down with the pressure washer first and then bring it in the garage before rinseless washing. Doing this gets rid of quite a bit of the dirt before I even make physical contact with the paint. I still use the 2 bucket method for when my cars are fairly dirty and I don't feel comfortable doing a rinseless wash on. I'd say give it a shot on a panel or two and see how you like it.
How many people use a rinse-less and/or waterless wash on a regular basis? Do you only use it as a last resort? I still find it hard to believe that using one of those wash methods doesn't produce swirls and/or scratches. I purchased ONRW hoping I could get past my apprehensions about using it to wash my car, but I cant. Have any of you experienced any problems with scratches, etc from using it? Thanks
