ok,if I understand,M205 ans finishing glaze WG with a white pad do the same job about M205 and M105 is heavy than WG swirl remover?? WG swirl remover is a medium compound and M105 is heavy compound??
WG Finishing Glaze has the same cut as Megs 205...BUT it finishes down better, better than most polishes in fact...WG Finishing Glaze is a no brainer in my view in place of 205.
However 105/205 are NOT the same as WG twins in terms of the 105/WG swirl remover half of the twin combos. 105 is pretty much the industry standard in terms of correcting paint that's in pretty darn bad shape.
Again, if you don't need the correction that 105 will give....the WG twins may be the perfect alternative to 105/205
Skip the WG twins and use Menz Power Finish. Almost the same cut as WG TSR, but finishes very close to WG FG.
Yep, that's what I'm saying.That's interesting. I have a sample of WG TSR that I haven't tried yet.
Are you saying that it won't finish down as nice if used as a one stepper on LC orange the way Power Finish does?
Yep, that's what I'm saying.![]()
