What level of polish to BUY?
WorldMattyBlue
I'm familiar with the method of using the least aggressive product first. My problem is deciding what to purchase! I have my first ever brand new car, a 2017 Subaru WRX.
The paint is in great shape as I've taken care of it since picking it up in July. Many polishes or compounds say "will remove 2000 - 2500 grit sanding marks" I'm trying to avoid buying two bottles of $40 polish.
Considering Wolfgang Total Swirl Remover 3.0 (removes 2,000 grit sanding scratches)
or BLACKFIRE Scratch Resistant Clear Finishing Polish (removes 2,500 grit sanding scratches)
I know you can't recommend much without seeing/feeling the paint, but i'd certainly appreciate some insight!
Always hand washed, two bucket method. Used a Nanoskin a few times so far, and only used spray wax. Spray waxed every two weeks. No major scratches/swirls.
Thanks!
you're going to get a handful of suggestions, here's one to add to the list...
Griots Garage BOSS Correcting Cream
I may actually have that...
Is there any photo guide showing "these swirl marks are equivalent to 1,500 grit sandpaper" and "these are equivalent to 3,000" etc.
I wouldn't get too hung up on the sandpaper grit equivalents.
The best thing is to find a compound and polish that work well with the soft Subi paint. You may never need the compound, but it's always good to have on hand in case you get some deeper swirls or some moderate marring. Pad selection should be a factor too.
My old Subaru Outback was very easy to correct with Meguiar's UP on white Lake Country Flat Pads. Occasionally I had to drop to the UC on a white pad to hit a few stubborn spots.
I know what you mean. The soft paint is another big concern. I have plenty of moderate compounds and polishes but they will be too much at this stage. Without having to buy a bunch of new stuff and see what works best, i'm hoping there is a method of determining the level of correction needed and matching that to a series of products. I know i'm in the fine polish category, but even then there is a swing of how aggressive the product is.
My gut is to get the Blackfire SRC Finishing polish (said to remove 2500-3000 grit marks) and try different pads to fine tune the cut needed.
Thanks for your help so far!
For a soft paint like Subaru, having just one good polish but a lot of different pad choices is good.
Subaru's classically have softer paint, sometimes very soft paint.
And as such have at times required some very gentle or refining polishes and euqally mild pads.. sometimes even watering down refining poishes with a finishing pad...
I would have this in mind when looking at polishes well suited and be looking at the lighter correction end of the scale...
I would also be considering having suitable pads and decent number fo them to keep the processas clean as possible, along with higher gsm MF cloths and perhaps eraser to minimise the likelhood of marring when removing polish residue...
In my current collection i have used carpro reflect and Scholl S40 to good effect on a Subaru.. I was running a lower speed and load than usual and was careful removing polish residue... it was silver so was certainly a little more forgiving than black...
All the best..
Try to pick up the Wolfgang twins (total swirl remover 3.0 and finishing glaze 3.0). Terrific combo to have around. The glaze will remove any hazing caused when using an aggressive swirl remover.
My recommendation would be an AIO or a very flexible finishing polish or swirl remover. Menzerna SF3500 is a monster product and very versatile. With Subaru paint I would even say that Mother's polishes would fit the bill as well; or Meguiars D151.
Used this combo on black 2016 WRX that had many dealer installed swirls last Spring w/ orange & white LC flat pads respectively. Menzerna 2400/3500 ('new' numbers/naming ) is Menz equivalent and a bit less expensive. I'd start with the 3500/WG Finishing glaze on a white pad first and see how that does.
Topped with WG Uber Ceramic to help protect soft Subie paint, has held up well for last 10K miles, occasionally refreshed with Gyeon Cure & Gyeon Wetcoat. Stays much cleaner as well, doesn't need as frequent washings to maintain clean appearance.
Sent from my SGH-M919 using Tapatalk
I've detailed a few Subarus over the years and on the ones I have encountered, all have had soft paint, such that Menzerna SF4000 is all that was needed for correction.
I suspect that with a high quality finishing polish and perhaps a medium cut polish if the paint is really hammered, is all you should need in terms of polishes. A good selection of pads will help dial in the perfect combo and I'd suggest a range from a jeweling pad to a light cut foam pad as well as lots of high quality MF towels.
PO106FA - SF-3500 (Equivalent to WG Finishing Glaze 3.0)
PO83Q - Medium Cut Polish 2400 (Equivalent to WG Total Swirl Remover 3.0)
Old numbering, is now the PO106FA - SF-3500
FWIW, the Lake Country Hydrotech pads work well with the DAT Menzerna polishes: Lake Country Hydro-Tech 5 1/2 x 7/8 Inch Foam Pads 3 Pack - Your Choice!
Thanks!
If you have any products do a test spot or 2.
If no products then do some research and try a line of products from same manufacture.
Optimum Hyper Polish would be another good one. Amount of cut is determined by aggressiveness of the pad. I think you'll be able to get all the cut you need and on a finishing pad it will finish really nice.
The last Suburau I did need car wash damage repair.
I started with M86 on a blue buff and shine pad. That combo left a lot of marring, so I switched to Menzerna PF2500 on a Lake Country Tangerine Hydrotech. It did an excellent job removing all of the damage, and left great gloss. I was using a PC 7424xp.
When I serviced this customer this year, I used the M205/PC/ blue B&S on one side, and Rupes Duetto/Keramik/yellow foam pad. It just needed a "refresh" for the season.
This vehicle is scheduled for service again this spring, and because the major damage has all ready been eliminated, a good finishing polish like Rupes Keramik, Menzerna 3500, or M205 is all I need.
If you're going to continue your method of spray washing every few weeks, and maybe renew the look yearly...two words.... HD Speed.
