600 for. Cyclo is way too much . Should be 350 usd 399 tops
Actually it's 650 usd with shipping to my country! And no warranty!
model number :
5C - Pro mark II 230V
Hi,
You could always check to see if the Bosch 1250 DEVS is available in your country. It is a dual mode device that can be a forced rotation (like a Flex 3401) and a free rotation (like a PC or a GG6, or pretty much the same as any other random orbital polisher) with a flip of the mode switch. Only thing is, it is only a 6" backing plate, so no change of plate sizes. Might be the best all around solution if it is available in 220V. I suppose you can also look at an XC3401 and a Flex XFE7-15 as well, but that is two very expensive machines. There are some DAS 6 machines that that are 220/240 V, ans seem to get a good review on the Forensic Detailing youtube channel (I think he favours the DAS6 Pro Plus). They don't seem to be too expenisve. He doesn't go into backing plates much, so I don't know if they would have different sizes available.
Junkman2000 did a review of it on youtube.
Thank you
You made my day!
I was thinking to buy pc and change the output in my wall to 110v
Just to use pc
Or I have to forget about machine carpet brush buffer
When I search for das 6 pro
I found interesting information
(same as Porter Cable) I hope what in my mind is right the brush for pc will work with das 6 if I understand correctly!
Specifications:
Orbit Size: 8mm
-Backing Plate Thread Size: 5/16" (same as Porter Cable, G220 and UDM's)
-Variable 6 Speed Dial: 2,500 to 6,500rpm
-Weight - 2.3kg (approx)
-Supplied with#two Velcro Backing Plates Size: 125mm ( 5” )# and 150mm (6")
-Fits 5", 6" and 6.5" polsihing pads
The brush carpet here on autogeek store
Is for pc and griots
http://www.autogeek.net/porter-cable-brushes.html
If the same brush will work on das 6 pro
Will be perfect machine for me
I need to contact autogeek and das 6 manufacturer to confirm this!
Forget to mention bosch not perfect for me I'm sure it's great machine
And I want now cheap and good Polisher
For me it will be first machine to start and learn with
And in the same time I can use it for carpet and cleaning leather
I'm waiting until Flex XFE7-15 arrives to my dealer after 2 month
So flex will be for Polish and the older for leather and carpet only!
If flex has good carpet brush i will not think about another machine
But they don't have
Thanks again everyone
Sent from my EDI-AL10 using Tapatalk
