What pads to use with Porter Cable to remove oxidation on a 2004 Trophy Pro
Hey Mike,
tried sending a message a few mins ago but not sure if it sent so i am just gonna send it again just in case.
looking at compounding and polishing my boat. it is a 2004 trophy pro with a all white Hull.
gel coat on the hull seems to be good but the top side of the boat has a dull/cream finish to it in certain conditions. looking to restore a nice bright white if possible.
boat is cleaned regularly and was detailed by a company before i bought it last year but looks like they only done the hull around the water line and that.
i ordered a porter cable 7424XP and it came with chemical guys hex logic pads.
did some reading on this forum and seems like the wool pad is better suited for gel coat?
looking at using the 3M line of perfect it compounds and polishes due to them being easy to get in my area. can also get other products as well.
looking for a little advice on what pads i should be using with the porter cable.
thanks
Does it look kind of like this?
More....
Buffing out the sides of any boat with a Porter Cable can be done with the right pads and products.
Buffing out the TOP CAP can be difficult because all flat sections of gel-coat around NON-SKID are going to be thin panels, or tight areas. What works best is a wool pad on a rotary.
Console area BEFORE
Robert Diterlizzi is using the Flex PE14 Lightweight, Compact Rotary Polisher with the 3" PFW thin pads to knock out the intricate areas and tight spots on the console.
A full size rotary buffer couldn't do this...
This is Rick's first time to one of our boat detailing classes and Rick wanted to learn how to use a rotary buffer, so I matched him up with Robert for some expert one-on-one training.
Robert and Rick making gel-coat shine!
Console area AFTER
Here's full write-up for this project.
Pictures: 16' Key Largo Center Console - Detailing Class - July, 2013
More....
And to be accurate - you can use small pads or large pads to buff the outside and the INSIDE of a boat - it' s just a matter of figuring out how to get the buffing pad onto or into the area that needs to be buffed.
Here's Andre using a 4" wool cutting pad for the thin panels...
Here's Bryan working the corners...
More....
I've never been a fan of Hex Logic pads or ANY type of foam pad with a DESIGN in the face of the pad. What works best are FLAT pads.
Also - The Porter Cable is a time-proven tool but it is a free spinning random orbital polisher and being a FREE SPINNING tool, it does NOT like big thick pads. Fact is - big thick pads will not rotate well on this tool. So I hope you got 5.5" Hex Logic pads .
And - gel-coat does NOT like soft foam pads when doing any type of abrading work. Gel-coat LIKES hard, sharp foam pads. The pads I always recommend are the RUPES COARSE BLUE FOAM pads.
I've shared a LOT of info recently on your topic in the below thread threads. A LOT of info. I'd recommend reading through them. Look at my recommendations. Read the boat owners feedback after taking my recommendations and sharing the results.
Help! My first detail project, and its a 26ft boat!
Polishing gelcoat makes it go dull - what am I doing wrong?
Gelcoat Polish Question - Removed swirls but also deep gloss? - Pics
And something else I share when it comes to buffing with any foam pad - you'll need more than one pad. In fact, you'll want more than a few pads. 6 pads would be a minimum to get you started because as foam becomes wet with product it stops doing what it's supposed to do.
By this I mean, a foam cutting pads stops cutting. This is because the foam is now soft and mushy.
If it were me?
I'd get a rotary buffer and a wool pad and use this to buff out the thin sections on top cap.
Use the Porter Cable and the RUPES blue pads for any flat sections.
I'm not sure what you're using for abrasive technology but in order to get GREAT results you need to use GREAT abrasive technology.
Abrasive Technology - THE most important factor when it comes to polishing paint
I help a lot of peope remove micro-marring after using CG products. If it were me and my time? I'd get our Marine 31 Captain's Compound. Works perfect every time.
i was looking at using the gel-coat PERFECT IT line of products by 3M. any experience with those ?
i will see if i can find some of the rupes blue pads in canada.
I have not used the 3M Marine line of products for years.... but when I did use them they worked fine.
3M has been at this a long time, they tend to make very good products.
so looks like i can get my hands on the rupes pads but i see there are a few different thicknesses. is there a certain one to use ?
attached a couple pictures of the boat. it is currently still in storage and i am away at work so thats all i got for now.
the porter cable list there speeds in OPM but the 3M compounds list everything in RPMs. anyway to cross reference these ? if i use the rupes blue pad with a 3M compound what speed do i run the porter cable at?
okay found some rupes pads.
going to order 5 of the 6 inch and 3 of the 4 inch.
no luck finding the Marine 31 Captain’s One-Step Compound & Polish in Canada so. any other brand you recommend over 3M ?
went through the links you attached lots of good info in them. wish i went through them before i ordered the porter cable kit from chemical guys. but ill just use the foam pads on my truck.
wondering if these are the correct steps
start off by washing the boat.
compound with a blue rupes pad.
polish with a blue rupes pad.
and wax by hand.
also noticed rupes has some wool pads for DA polishers.
and in one of your links i seen you used lake country purple foam wool pads. i can also get those.
First - NICE BOAT!
blambert said:
1674805]okay found some rupes pads.
That will work. Buff until all pads have become wet or soggy and then stop for the day. Wash and dry the pads and they will be ready to go for the next day.
Yeah - Marine 31 is only available online. My next go to product would be either the Menzerna FG500 or RUPES Zephir Gloss compound.
That will work.
and wax by hand.
That will work. If it were me I would machine apply the wax too. The machine always outperforms the human.
RUPES makes great fiber pads. In context to the detailing world, these are fairly new. I have not used them to try to do what you're doing. I don't show these in my classes because I show a FULL BLOWN process that by-passes this approach.
For my classes I bring in boats in HORRIBLE condition and we machine sand them and then use rotary buffers with wool pads to remove the sanding marks. After that we machine polish. The results are a "Show Car" finish on a boat. But it costs more to do this and requires more tools and products and a little training goes a long way.
Here's the deal, (gosh I type this over and over on this forum),
FIBERS ARE ABRASIVES
This means they will CUT better than FOAM. The problem is they CUT and this means after you use one, while it may have removed the defects, in you case oxidation faster, it leaves cuts called micro-marring in the paint.
Micro-marring comes from using orbital polishers.
If you were to use a fiber pad on a rotary buffer it would leave HOLOGRAMS.
Both make the paint LESS clear and glossy and also increase the surface area which then promotes or accelerates future oxidation.
The remedy is to cut first with a fiber pad - accept it might look dull and the RE-POLISH using a sharp, hard foam pad. This will undo the dulling of a fiber pad.
This is all deep stuff. I have to type out info for a WIDE SPECTRUM of people that often times hold MY information to the highest standard. If a person is not that deep into perfection, then here's the quick, fast easy way to make oxidized gel-coat shiny, not perfect but shiny.
Get a GREAT Marine One-Step Cleaner/Wax and machine apply using a rotary buffer and a traditional wool pad. This approach will remove the oxidation FAST and leave the gel-coat shiny. Then wax over this and done.
I've actually shown this in my classes for the TOP CAP of a boat because trying to do show car detailing to the COMPLICATED design of a top cap on a boat is TIME CONSUMING - especially if you want to use a CERAMIC COATING instead of wax.
There's million ways to skin this cat and most will work. Which way is best for you depends on your expectations for finish results and how much time you want to invest.
That's a fairly old article. Always look at the TIME STAMP for anything I write. I write in such a way that the info is accurate over time but products CHANGE. Those pads you saw are still around, they are called Purple Foamed Wool Pads and do they work? Sure. Are they best for what you want to do? I'd say "no". If you want to cut faster then get these RUPES pads
RUPES 3.5 Inch Coarse Wool Pad
6 inch RUPES Coarse Blue Wool Polishing Pad
A couple comments about fiber pads, (any type of fiber pad)
Unlike a foam cutting pad, which loses it's cutting ability as it becomes wet or saturated with product, a fiber pad will cut fairly consistently wet or dry. So you can buff longer with a fiber pad.
If you see any micro-marring or dulling after using a fiber pad and then wiping off the residue, assuming it's not the product it's the pad - you can re-polish using foam and remove the micro-marring or dull looking haze.
The individual fibers CUT the surface whereas a foam pad has a UNIFORM SURFACE TEXTURE - it's this uniform surface texture, (plus the fact that it's foam), that enables a foam pad to finish out NICER more CONSISTENTLY over a wider spectrum of materials, (gel-coat, plastic, paint etc.), than a fiber pad.
The above is a LOT of info to soak in, I hope it's helping more than it's hurting.
More
For those reading this into the future....
Here's why buffing out the top cap of a boat is a LOT more difficult that the hull.
With the hull you have for the most part large flat panels. These are EASY to buff.
With the top cap, you have lots of shapes and designs. You have thin areas of smooth gel-coat surrounded by some type of NON-SKID. Non-skid surfaces can be,
  1. Molded-in.
  2. Painted on.
  3. Adhesive-backed.
Buffing out the smooth portions of gel-coat on the top portions and inside this boat is challenging compared to large flat panels on the outside. It can be done, it's just a challenge.
Where you see the green tape here is on the edge of molded-in non-skid. Andre is buffing out the SMOOTH portions of gel-coat next to it.
Same thing here. I've taped-off the painted-on non-skid surfaces next to areas I'm going to machine buff with a rotary buffer and wool pad.
If you don't take this stuff off you WILL get compound, polish or wax into the non-skid surface and it will be a bear to try to remove with a toothbrush.
I'm one of the few guys I've ever met that goes to this length to protect non-skid, save my reputation a detailer and prevent me from trying to clean up non-skid after the buffing is done.
So again, the sides of a boat = EASY
The inside? Difficult.
And this is why I stick to buffing out cool muscle cars from the 1960s and 1970s, big flat panels, no stupid plastic trim like you get on new cars. Mostly and simply because I'm L-A-Z-Y. :)
And the one boat I did own for 20 years was like a muscle car, it was EASY to buff out.
once again good info mike. thanks.
so would i be better off buying a buffer like the dewalt dwp849x and a wool pad for the hull. and use the porter cable with some rupes pads for the top side ?
so been doing more reading. new approach
-ordering a dewalt DWP849X.
-ordering RUPES ZEPHIR GLOSS course compound.
-wool cutting pad for polisher
-rupes blue course foam cutting pads
-small wool cutting pads for tight areas with the porter cable.
-start by using the wool pads and RUPES ZEPHIR GLOSS course compound.
-go to rupes blue course foam cutting pads on porter cable and RUPES ZEPHIR GLOSS course compound.
-apply wax. not sure on what wax to use and also not sure on what pad to use to apply wax?
should that get the job done ?
Mike - you go above and beyond to help us out on this forum. Thanks so much for all the information you posted in this thread. This is the reason I am loyal to Autogeek. Not only do we get great products, we get great advice.
