Whats the Best Wheel Sealant?
The Dp Wheel Glaze, Poorboys Wheel Sealant and Opti-Seal all work great IMO.
I've used both and the PB is easier to remove if you let it set up too long. Wheel wax when set up too long requires you to spritz it and really rub to remove, the PB no issues for me. I apply all four wheels then remove all four wheels. People think I'm nuts pushing my stool around the car twice. Good for the entertainment value I guess.
I tried doing the four wheels and then buffing out the wheel wax, man did my arms hurt. Now I do two at a time.
I have some Klasse AIO, and plan on ordering the Klasse SG. So think I will order the Poorboys also, and compare the two. Thanks.
The way I drive, any wheel sealant would be burned off in less than 20 minutes :D
I dont think that is true when a durable Sealant like DG105 or FK 1000P is applied. I believe that these are designed for high temps.
Anything with a wax is toast though.
I have been looking for a good wheel sealant but all I see is the wolfgang and the collinite metal wax. Are these the only 2 auto geek sell? If so which one do you suggest?
Poorboys Wheel Sealanty
DP Wheel Glaze
Optimums Optiseal
Rejex
There are a few of us that use Duragloss 501 over DG 601. 501 is a very durable Marine All in One (AIO) that is safe on metal or clearcoat. 601 is a Bonding Agent that improves durability by 50%. DG 105 is good too. Just my $.02.
+1
I used the Rejex applied with a microfiber glove.
Works very well and extremely easy to use.
i've been happy with the Meguiar's gel, looks good, not real shinny and last weeks (IMO)
I've used
PB wheel wax,easy on just as easy off.
Opti seal WOWA
I have and may try 845IW and see how that goes,and then hopefully stick with one.
Is there a difference between ordinary sealant and wheel sealant? do they supposedly last longer? hi temp resistance or is it just a marketing gimmick *no offense*, they're both sealants
IMO any good sealant will do a good job on wheels, Just my $.02 FWIW!
Rich, IMO the 845 is doing the durability part. I bought Sonus Wheel SSealant a few weeks ago and applied to the chrome rims on the XLR after using Sonus Chrome Polish, They look great. Unfortunately AG doesnt sell Sonus. Alas the new Ford has polished aluminum 20's. The 07 had 18" chromes. The 20's are gonna be expensive when the POS PIrelli Scorpions are shot. The 07 Pirelli's lasted only 27K miles. Im a Michelin guy.
Well now AG sells these and other great Sonus products!
I feel, that I am seeing more people going with sealants over waxes on the wheels.
Think I should go with the Klasse AIO and sealant on the wheels since I have them. Since I have some wheel wax left, I am guessing that it can't be used in conjunction with the Klasse twins on the wheels? Overkill?
Hopefully weather cooperates this weekend, and can do a wash.
