what's the deal with this?
you can use it to wetsand headlights/isolated areas, and apply wax/sealants. it's too bad the megs xtra-cut discs didn't come in a 3" size (only 5" & 6") because it doesn't have the foam backing like the cutting and finishing discs and i would imagine it would cut quicker and not bog down as easy...
With a 3" polisher like my PC, the energy is focused in such a small area that the Megs Cutting MF pads cut pretty quickly and easy to keep rotating on speed 5-6.
That little scratch looks to me like it might be a crow's foot type of crack rather than a scratch. If so it probably goes deep beyond the base coat. Could that be a possibility?
As for the GG 3" polisher, I've always looked at that as a cutesy little toy rather than a real polisher. Don't own one so couldn't say for sure..
DAVE! good to see Ya around again! LOLOL:props:
yes, the PC will do it just as well and quicker, but the GG3 has it's uses and you can hold it comfortably with one hand which i like. buy a carpet brush and you can use it to scrub seats, etc,. if you don't want it, send it to me... :dblthumb2:
+1 on the carpet brush
Pick-up a stiffer one to use for scrubbing tires
Is the Griot's 3" less powerful that an old Porter Cable 7424 ?
