Was that sarcasm? How do they make it easy when they have 7 products that do the same thing and they all pretty much have the same description?
Back to why I started this thread, I saw a post tonight with someone asking if a particular polish (that was suggested to solve his problem) would work with his 5.5" LC flat pads...and I thought, "does that mean he thinks he might need a different size pad to use that polish?" I mean sure, there were a lot of different pads way back when, and a lot of colors, but how many distinct lines of pads does LC have now? Flat, CCS, Hydro-Tech, Hybrid, HD, Thin-Pro, and that's not even getting into the wool and MF. And in some cases 3 or 4 diameters of each.
I have to say I started on forums at MOL, and it was pretty simple, there wasn't that much to choose from, you got your G100, you got your 3 flavors of foam pad (in one diameter) and you got your 3 or 4 80-series polishes, and that was it. Then someone at MOL mentioned Autopia...and then the world got a little bigger. And now it's just crazy.
Edit: I forgot the waffle pads. Since I mentioned Autopia, way back when we used to preach "process > product", which has kind of been lost and also why perhaps it's more confusing than it was. Maybe I'm wrong.
