Which Foam Sprayer do you recommend?
Pictures of the foam quality?
Just did another rinseless wash today and took some pics using the OP Ecowash. I mixed half a capful of OP with 1.25 liters of water in the iK foam pro 2+ sprayer. I used the medium tip. If you want drier foam, the iK unit comes with a different tip for that, but I did not try it. Here are the pics.
Before the foam:
And with the foam:
New player in foaming world. Suprised PBMG hasn’t come out with a foaming WG Uber…. Would be a hit.
I ordered the AMMO sprayer and I got the Mini air compressor. I thought 1st to make the pouch and still might. But first I'm going to stick Velcro loop on the sprayers I have. And hook on the back of the compressor. I found the best quality valves I could find in the shortest size. 32mm
I have a few pumps that arrive tomorrow. I want to see which one is the best.
View attachment 75621View attachment 75622
I thought it will work with any of them! For my purpose I'm only doing one off's for rinseless or wheels. I just use the IK F Pro2+ For wheels with B.Buster and the Epoca Archetype PRO VITON Pressure Sprayer 1.5L AKA AMMO. with Fuzion.
But if I was at a shop I would probably us the IK 12 or Marolex Axel Foamer 7000 an add a schrader.
In Australia they might be cheaper? I just hate when other companies slap there name on them and charge double. I didn't want to wait to order the Epoca Archetype PRO VITON AKA AMMO
and wait 3-4 weeks from Poland $27 + $8 Shipping $35 AMMO $60 + $10 freight (Double $$$) I do understand about companies need to make there Keystone but like Griot's they charge $39 but have a weird base.
Here is the BigBoi here in the states $75 View attachment 75625View attachment 75624
This one is ok. Use up product quickly compared to a standard foaming pump sprayer. Also if the battery gets wet at the bottom it will have issues. It needs a weighted straw. The more I used it the more I realized its limitations and in the end it is not worth the price.
I have both, the foam and built is superior on the IK, but the capacity of the Kwazar is untouchable. The IK runs out after four rims/tires.
The price going up 50% didn't help. I stopped using mine as a sprayer after getting an electric plant sprayer that weighs much less. I think it'll see use as a foamer this winter though.
$75 = $116 Australian dollars not bad. They sell the BigBoi for $140 at the moment
The pump far exceeded my expectations. It's built like a tank! I wasn't able to actually try the sprayer with it yet. I thought it was funny that the MFR. has a video on Amazon of it being demonstrated with this exact pump foaming a car. the Super-Stretch Wrap-It was the ticket.
View attachment 75632View attachment 75633
IK FOAM Pro 2 + W/Xiaomi AIR PUMP - YouTube
NO MORE PUMPING IK FOAM Pro 2 + - YouTube
How is the pump attached to velcro?
View attachment 75659View attachment 75660Stuck really good to the rear of the compressor.
I ordered the Marolex Axel Foamer 7000 on sale at Clean Garage $140 View attachment 75662
And found this to wrap around it.View attachment 75661 Love the size and long hose on it. And I know after trying this out today that it will be a
HOME RUN!
GAME OVER!:laughing:
So strap around sprayer and then doubleside velcro on strap and pump?
Yes. I stuck the plastic side of Velcro to back of pump.(HOOK)
The straps come in a 6 pack. I had them for my buffer cords and vac hose. They have Velcro on both sides. Hook on one loop on the other. I just tighten it to the bottle and the pump is like cemented to the strap! SOLID! I'm actually stunned how well it worked.
If you look closely you will see:View attachment 75663
For the IK foam pro 2+, are issues with capacity about air running out (& needing to re-pump it), or is the reservoir not large enough to cover, say, a sedan?
Because even if the foam pro 12 is better, is it really better than 2 foam pro 2+? (It sounds like it might spray better?)
Yeah tiny reservoir. Will be pumping/adding air for ever. If you use it with the tire pump hack it would be ok.
The pro 12 is nicer in that it can be rebuilt. The wand sprays way better. Better quality. Both my IK hand foamer’s failed. The were the originals not the 2 but heads look very similar.
You will end up buying a foam pro 12 if you foam a lot. Just a matter of if you wanna waste a lot of money before you do it….
