Which Foam Sprayer do you recommend?
Yeah tiny reservoir. Will be pumping/adding air for ever. If you use it with the tire pump hack it would be ok.
The pro 12 is nicer in that it can be rebuilt. The wand sprays way better. Better quality. Both my IK hand foamer’s failed. The were the originals not the 2 but heads look very similar.
You will end up buying a foam pro 12 if you foam a lot. Just a matter of if you wanna waste a lot of money before you do it….
I understand. Thanks for clarifying
:xyxthumbs:
After getting tired of hand-pumping, I bought the Pro 12 with the air-valve. Love it. If your compressor fails, you could pump it up by hand.
I like my little IK Foamer 1.5 for wheels. Hild just enough for all four, zero waste. Holds a charge for weeks too. Forgot to bleed it off once.
Sent from my SM-S911U using Tapatalk
