Hi Mike,
Thanks for all your thorough replies, I finally managed to get my courier address sorted out. So I've got just a couple of questions before I Buy the things.
1. I would like to, based on how I've described the overspray situation in the thread, try and use the PC, with wax/polish or simply car shampoo and see if that removes the overspray? What do you think of that? If yes, what products would you recommend?
2. Claying time.
3. In the last page I've attached a photo of how dusty the car get's after one day of travel during the weekend, they're improving the roads to a 4 lane road, so there's a lot of dust going around, even some sections are dirt roads ( and that's right after being washed, only washing though, i've not turtle waxed for fear of "sealing" the overspray in). What would be your recommendation pre-claying to ensure that the surface is properly clean?
I Currently use this:
Amazon.com: Turtle Wax T-79 Zip Wax Liquid Car Wash, 64 ounces: Automotive
And what I do is, let the dirty panels soak in foam, then spray with hose, then soak in foam a bit more, then wipe of without any pressure with a soft car was sponge.
4. Though you posted what backing plates are, i've No idea which specific one to select :S ? So far I think this is the best choice :
lake country 5 inch backing plate, 5 inch backin plate, 5 inch hook and loop backing plate
5. Re on the plastic trims, I really don't want to use any abrasive that will strip the finish from it and then I've got to dye it back afterwards, I've been searching in the forums and some people recommend baby oil, IPA or even clay, Those will my three attempts before trying anything more abrasive?
6. After I uses turtle wax polishing compound to clean the windshields, water seems to stay a bit more on them, i've seen a couple of rain products such rain-X, but do not know about any specific one, so again, which product would you recommend ?
From your response to my OP: you suggested:
PC 7424XP
Pinnacle Ultra Poly Clay
Pinnacle Clay Lube
Pinnacle Advanced Finishing Polish
Pinnacle Liquid Souveran Wax
Lake Country Pads - Get 2 Orange, 4 white and 1 Blue
Just in case, I plan to get 2 clay kits, better to have extra to try on the plastic trims.
SO based on the above, how would you modify add/remove from the above list?
Sorry if I'm being a nag, but everything will take around 20 days to get here, so I need to be sure I buy everything correctly and be sure I don't miss anything, because it's not like I can go out and buy it right at the moment I need it.
7. Based on the dusty pic in the thread, what would you recommend to avoid getting damage by the dust?
8. On shipping, not sure if this is your area, but, do you guys send every item in a single bulk package?
And once again, thanks for your time !
Edit: For some reason If I tried to send this post I would get 500 internal server error, so I just posted then edited and pasted, but sat through several ours thinking it was something with AG servers... The same error when trying to PM this same message
