mhawkes214
- May 4, 2012
- 2
I am new to the world of polishing. I purchased a Flex 3401 and a host of Menzerna products. I started with the least aggressive solutions, but none of them worked to remove all the swirls. I ended up starting with PG-1000 with a yellow Lake Country pad. It worked well to remove the swirls and some lighter scratches. I then moved to SIP-1500 with orange Lake Country pads. Again, the results were great. Here is my dilema--where do I go from here? I have PF-2500 and SF-4000.
Can I skip to SF-4000 if I had good swirl free results with the SIP-1500 or do I need to do the intermediate step of using PF-2500.
If I need to use the PF-2500 instead of jumping to SF-4000, should I use the SF-4000 or jump to the UF-4500?
Suggestions are appreciated. I have searched and searched but I have not found info on this type of topic. I really need some expertise on how far I can jump in between steps.
I have a 2005 Honda Accord with Graphite Pearl paint. It is a fairy dark color--not sure if this is a consideration in the process!
