FUNX650
- Dec 1, 2010
- 21,057
- 1
•Well crap, a chav?...Ok, whatever.
•As to:
Re: "Why I am ditching my favorite sealant
(Polymer Net Shield) for CQuartz UK.
Is PNS flawed, or is it just me"?
-PNS is not flawed.
Haven't read all the responses, so might be told already. But most shampoos and the CG foam for sure have gloss enhancers in them. These will cover the PNS and mask the water behaviour from PNS. So PNS isn't failing. You will havrle the exact same problem with CQUK, unless you use reload every time. But themln you might as well use BSD for PNS
Im fairly confident Honey Dew doesn't have gloss enhancers.
I don't know what you mean by touch less? How would I not touch it?
I do a regular wash.
I was basically asking if you were just foaming and rinsing (touch less) which may not remove the contamination, or doing a regular wash with a mitt. Maybe you should try a different shampoo. I have been using PNS for over a year and have never had the issue that you are having, even with one of my cars being parked outside for the past 6 months.
•As to:
-PNS is not flawed.
Mainly because it never inhibits beading if the car stays clean, its only after it gets hit with contaminants that the beading never comes back.
It certainly has gloss enhancers. These will also give you beading, but might be muted much easier by contaminants then PNS. So you'd actyally should be blaming honey dew or the shampoo you are using.
People oftwn forget that working with (semi-) coatings requires a lot more attention to which products are used to maintain them. No wax or gloss enhancers should be present in the maintenance products. Same with a QD. These all cover up the coating.
Change your shampoo to carpro reset and use a decent snow foam that only cleans. You'll see a world of difference
When people aren't up-front to begin with...Annoying.
What soaps play nice with PNS?
what about rinseless wash? I have ONR wash/wax..should I get the plain?
I don't know regarding the availability of it in USA, but Sonax Nano Lack Protect is pretty good stuff, I believe it is stronger than PNS.
It states a durability of 12 months.
A bit off topic, but a sealant that really amazed me, regarding durability, is PolishAngel Viking Shield; I used on wife's car, and it is going strong after six months, and her car is bombarded daily by bird bombs, she parks under the trees at work.
Best regards.
