On my WRX my window trim is turning white in some spots. I’ve tried 1Z Einszett Gummi Pflefe and PB TR with no luck. I’m wondering if there’s anything else that can be used on it to bring color back?
Really Gummi Pflege didn't work? It worked awesome on my 08' Impreza, but then again it is an 2008. I did however use it on my girls 1998 Firebird and it made her trim new again. I'm assuming you did clean the trim before using it right?
Also, if the trim is not clean (as stated above) you should definitely clean it with a specified product instead of just your car wash soap. I would try one of these:
Griot's Garage Rubber Cleaner, exterior trim cleaner, clean rubber moldings, tire cleaner, griots garage
Corey (CEEDOG) likes the rubber cleaner. I have never personally used it.
Meguiars #40<br>Vinyl & Rubber Cleaner/Conditioner protects rubber, plastic & vinyl interior surfaces. Meguiars # 40 Vinyl & Rubber Cleaner and
I have personally used this but it doesn't work as well as I'd like for it to. It does work quite well.
There's no point in buying Griot's rubber cleaner if you have a quality APC. The APC will do the same thing. If you need stronger, just dilute it stronger. JMO.Thanks, I'll give Griot's a try.
I used APC+ 10:1 to clean it and applied Gummi Pflege but it didn't bring the color back at all.
Sorry guys. I might have miss worded my original post. I'm talking about the rubber trim/seal that goes around the windows.
Try APC 4:1 and if that doesnt work, try Forever Black for tires. IME Ultima is best after restoring color with APC. Good luck Slava!I used APC+ 10:1 to clean it and applied Gummi Pflege but it didn't bring the color back at all.
