Hey
I understand the concept (as well as read the articles) on do a test spot with the least aggressive product first and work from there.
Would I start with the Swirl Remover and if not getting the results then work with a more agressive pad? if still no results, then go to the Uber Compound? Or do I start with the finishing glaze? or does the finishing glaze go after you do the above 2?
After correcting (the above steps per your instruction)? would i use the polish enhancer? does this fully prep the paint for a LSP? Also does it replace doing an IPA wipedown? Is it like CarPros eraser?
I know its alot of questions, but i want to do it right?
thanks guys
thanks guys
