Tato
- Nov 27, 2013
- 2,157
Hello Mr. Mike, Hello Friends,
This may look like a common question, I've searched and read a lot about this subject. I could even had posted the topic on rotary buffers thread, but every case is different. Listening to an expert is a need in my case, but I always appreciate any member comments.
Actually, I only have Meguiar's G220v2. I use Foam and MF pads, M105, Uber, M205, Menzerna's polishes, etc. Although I can do a lot with my DA, I also feel I'm in need of a FLEX 3401 or a Rupes 21.
Locally, I can order a Flex 3403 for a decent price, but that's the only option at this price rate. A 3401 will be 3 times more expensive (and it means a huge amount).
Would ordering a 3403 will add to my needs, or I'll always miss a Rupes or 3401? I'm in need to fill this gap and using my actual DA for heavy polishing and finishing.
Rotary is also a concern here, although I do very well with DA, never used a rotary, and I'm very afraid of ordering a rotary and start messing my actual good work.
I want to speed up in corrections, and specially on vertical panels where I believe a lightweight rotary would be more powerful than my actual DA.
Would I save $$ and buy a Rupes 21 when I can instead of 3403 now?
I pretend to use 6.5 inch pads (I already have) with the rotary.
Thank you in advance for helping me to decide.
Kind Regards.
Kind Regards.
