supercharged
- Mar 7, 2006
- 7,305
Will Pinnacle XMT series swirl removers be available in larger then 32 oz refills? More ounces for the buck.
Just wondering?
Just wondering?
Pad Cleaner and Conditioner in gallon size would be great!Avengeance said:Not to go OT but sorta the same....
I wouldnt mind seeing XMT pad cleaner and conditioner available by the gallon as well. That would be nice.
#3 XMT is great give it a try first then hit it with XMT 1Whitethunder46 said:I'm about to order the XMT series... How do you all like it? Is the #3 very good at polishing out the deeper swirls and such? Or is there a better compund you recommend?
FloridaNative said:I love the XMT 3!! Look at this picture of this VW bug. Half of the door and the fender had been done in XMT 3 and the other half was unpolished.
Yes. This car had clear coat failure in several places so I had to treat it gently. I used XMT 3 with the orange pad on the entire car, followed by XMT 1 and the polishing pad and finished it off with the XMT carnauba finishing glaze applied with the finishing pad and then Souveran paste wax. Here it is after I finished the detail.Whitethunder46 said:wow, that's amazing. Looks like you used the orange pad?
And did you go straight to a glaze after that, or did you use #1?
Whitethunder46 said:That's absolutely gorgeous. Is it recommended to use the #1 after the #3 usually? Or is it safe to go straight to the glaze after the #3?
