Your favorite spray wax? (for protection)
Oh hydro max is the bomb. More of a sealant. (in fact it is) It was introduced to make application a bit eaiser over hydro seal. Still love hydro seal too tho.
In fact this spring it's going to be....
1. AMIGO
2. HYDRO SEAL
3. HYDRO WAX AS YOU DRY TO MAINTAIN
Hi everyone,
It seems like I'm going to try either D156 or Hydro Max.
Hell, I might just try both eventually and give a review!
Hi everyone,
Hydro MAX > D156 is every aspect.
Not sure if D156 is cheaper?
Why so? Beading? Shine? Or just all around?
All around. Most importantly though is durability. It will outlast D156 by a long shot. If you plan to apply D156 every week after your wash, durability wouldn't be a big issue.
I'm more of an every other week type of guy. Would this product be good on white?
They're BOTH good. If you want better durability, go with Hydro MAX. It's pretty simple. :)
Absolutely. It looks great on all colors. You can use it on wet or dry paint. Obviously, the less wet, the better durability.
True true. This seems like the product I'm going for. Have you noticed any better results through layering?
I've never really layered it, so I'm not sure. I've used both and I'm just letting you know which I like better. :dblthumb2:
Thanks Mark!
It seems like I'll be ordering Hydro Max and maybe D156. Is it Ultimate Quik Wax's counterpart? Or are they the same thing?
Thanks Mark!
Same thing, different packaging.
Okay then, Hydro Max it is! can't wait to see how it pops on white!
Good choice!!! :props:
Hydro MAX is loaded with polymers. FYI, You don't need to spray every square inch of the panel, just enough to get good coverage. It spreads nicely. Make sure you shake if before and while using it.
