My next project within next couple weeks.
This is a 31,000 miles barn find. All original from South Carolina.
Been garaged since 1986/87!
Current thoughts as of now, subject to change, is to perform the following:
1. Combination of waterless and rinse less wash.
2. Go straight to Blackfire One Step with CBEAST and Rupes yellow pads.
As of now, probably won’t be doing the megs #7. But will see once I clean and test paint. My gut says it’s that hard single stage enamel paint.
Tom. View attachment 72319
Thanks 2black1s....
Saw that in the attachment that 57Rambler posted.
I suspect its a repaint...
Some overspray onto driver's side fender wells.
Driver's side 327 emblem has touch of white on its edges.
I'm guessing enamel...
Question--Is acrylic lacquer on the hard side?
Tom
In its day acrylic lacquer was harder than other paints from the time. It was also more brittle and lacked any meaningful flexibility. That's why lacquer checking, or micro cracks, are so common on old lacquer paint jobs. It's the hard, brittle nature and lack of flexibility that is the root cause of the cracks.
As compared to the hardness of today's paints, I really can't say for certain as its been a long, long time since I've worked with acrylic lacquer. Any assessment I'd give you now would be based on my recollection from years ago when I worked a lot with acrylic lacquer. It's been so long that my recollection could certainly be skewed.
Looking back to the heyday of lacquers, I'd have to say that its primary benefit over other paints was the ability to produce truly glass smooth finishes. To this day, if you wanted the most perfect finish on a custom paint job, I think lacquer should be in the discussion. I probably wouldn't choose it, but it should be part of the discussion.
Don't get me wrong, you can achieve a really nice finish with today's paints too, but the light-bodied or thin nature of lacquer helps.
Other than that, today's paints will outperform lacquer in just about every other way.
Cool project and I'm sure you'll do an awesome job on it! Based on your pic, I'm assuming you found the CBeast and BF One Step strong enough to knock it out? I'm hearing good things about that CBeast.Will hop to it tmw! Need to have it done by Monday
Tom
If it's truly original, then the paint is acrylic lacquer, as are all of GMs cars of that era.
Hummm....I'll say borderline...
Might break out the BEAST, but will tread carefully.
Tom
The top stitches are dry rotted---Owner plans to replace the top.
I went ahead to see how much dirt I could pull out of the top.
Did the vacuum, wash. Best cut was the Woolite, distilled water with Sonax brush!
Did not bother with cleaning wheels---They are going to replace them with new rims/tires.
The big take away from today....Embedded dirt!
Machine polishing removed the embedded dirt and restored gloss and color.
Tom
