Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 8
- Thread starter
- #41
I watched it twice.
Me too. Made the wife watch it with me.
The first time concentrating on what was being said. The second time focusing on physical things such as pad rotation, compression, speed, etc. We're so used to "instant results" these days. The video makes it clear just how much time and focus goes into a start to finish job on one vehicle.
Really tried hard to put a lot of correct info into this video.
When I first contemplated buying a DA, I honestly thought I could probably polish out a car in an hour (I knew absolutely nothing about the process, nor had I thought much about it).
And I think that's a common perception. It's awesome for people to see videos like this so they know more about what's involved before jumping in.
A lot of the frustration one might encounter when first starting out can be generally avoided with realistic expectations. And this video does a great job showing what is involved.
I try to share how long it takes to machine buff out a car in a lot of different venues I work in including on this forum and what I tell people is this as an example.
If you were buff out an average size passenger car, something like a 4-door Honda Accord. Assuming the paint was filled with swirls and scratches and the goal was 95% of perfection, then the compounding alone would take at least 6 hours. And that's for someone that's good at this type of work. Read the word good to mean experienced.
If a person plays on their phone or stops buffing for any other reason then it will take longer.
That also means getting in there and getting busy. By this I mean get to buffing and don't stop till you're done. No phone breaks, maybe a water break or two but no goofing off.
The compounding step takes the longest because you cannot simply move the polisher FASTER in order to get the job done quicker.
You must divide larger panels into smaller sections and buff each section out independently.
You must move the polisher slowly over the surface making controlled section passes over each section of paint.
I also tell car owners this one of the ways you can tell a good job from a bad job. If a detailer tell you he can wash and detail your car in a few hours he's probably doing more damage than good.
Thank you for watching the video and for sharing your comments.
