Test Spot Results
Did 3 Test Spots starting with the least aggressive products and pads to get the job done...
After each section was buffed I then wiped the section clean using MS followed by IPA.
The percentages below are simply based upon experience from doing compound and polish testing. Usually it's timed, for this test I just counted to 6 section passes after 1 pass to spread the product out.
- Test Spot 1 - Optimum Finish with a Gray CS Finishing pad on 1000 RPM - 65% Swirl Removal
- Test Spot 2 - Optimum Polish II with White CS Polishing Pad at 1000 RPM - 80% Swirl Removal
- Test Spot 3 - Optimum Compound with an Orange CS Cutting Pad at 1000 RPM - 95% Swirl Removal
After the compounding on Test Spot 3 I then re-polished using the gray finishing pad with the Optimum Finish and chemically stripped again with both MS and IPA and the finish looked swirl free. The sun is too far down in the sky to pull the car out and inspect in the sun so all I used was the Brinkmann Swirl Finder Light.
Tried to take close-up shots across from where I marked the painter's tape with the numbers, 1, 2, and 3 but what I could see with my eyes I just couldn't capture with my camera.
Bump,
Mike, I see that you used same RPM for all test spots.
Just wondering, because I also met someone who compound and polish at only 600rpm even with smaller 3" pads.
I think the rubber hand pad on the head of the buffer was a great idea.
I use mostly a rotary with a stick but I def like that feature on the d.a.'s that I have used. It's comfortable and you have total control over the movement of the machine.
Glad to see they incorporated that on the DeWALT.
