Really liked them. I have some feedback to Dr. David Ghodoussi already. All have a good buffing cycle and easy wipe off with excellent results.
I found the compound to wipe off easiest if you wiped it off immediately, so set your polisher down and wipe the residue off and it wipe off easy. Wait a little while and it can be a little harder to wipe off but still not bad.
I only used foam pads with all three products so I still need to do some cutting with the compound and wool pads but we'll have a chance to do this during this
Sunday's Advanced Class as I usually have out 5 different brands for use with the rotary buffer and Optimum will be one of them.
The other two products worked very well, both finish out leaving a super
clear, high gloss finish and while a lot of people might not understand, clarity is a top goal when working on clear coat paints. You need the clear coat clear in order to see the color coat under it and gloss comes from smoothness, so one of the primary goals of any machine buffing is to create smoothness and both products left a clear, high gloss finish, so they're reaching these two goals.
