DFB
- Aug 12, 2019
- 5,016
- 3,224
Sio2 infused? The NV stuff? What you order? You can get AW in the US. From the US distributor.
I like the Mystic Bubble a little better.
Mystic water is Sio2 infused. NV I bought Precision and Jet. I did find TS in US after you mentioned it, but only Autopia so far? Does MB serve up good foam?
I know most PH Neutral soaps aren't really big in that arena. I did however find Mystic water to be interesting. I'm curious if anyone here has used it?
Just to provide a little more info regarding NV soaps -
There are two soaps in their lineup, Snow and Snow+. In theory, the quoted pH levels for both are 7.2 and 8.1 respectively. However, when I pH tested these two products, soaps that I had been using for many years, Snow measured about 9.7 and Snow+ measured about 12.1. Measuring Reset back to back with these soaps, it measured in at 7.2.
Both soaps are excellent for slickness and foam quality...........................and with those pH readings, very good at cleaning. Despite being told these readings are abnormally high, but they are still safe for use on ceramic coatings and stronger LSP's. I have stopped using both of them now, I think if the product is said to be a certain level, then it should reflect that in the real world. If you have these soaps, be sure to measure them out accurately according to the directions.
As for Jet, you will love that product. Jet is as close as you can get to a ceramic coating in terms of water behavior.
